2019-05-08, 18:45
All,
Board: Raspberry Pi3b+
SD Card: Microcenter 32GB
Cooling: Passive
OC: replicated with small memory/gpu oc (found this helps the menu system when movie is playing) and without.
OS: LibreELEC (mpeg2 & vc1 lisc applied)
Topic says it all and it is vague... But i was able to finally replicate the freeze and hopefully someone could help me out.
It appears that the system will lock to a black screen if I am running a background procress (such as a refresh lib) and back out of a playing video (movie, aerial screensaver). Exact steps i was doing at this time were doing a library rebuild with PlexKodiConncet and the Aerial screensaver came on at the same time. I have had this issue with other videos playing and it appears to happen also when IO is happening on the system.
I am able to ssh into the box.
I have the last few lines of a log that i was able to catch, by putting the system into debug mode and repeating the crash. I will include the last couple of seconds, since that seems to be what might be relevant.
https://paste.kodi.tv/idubegalal.kodi
Cooling: Passive
