Full Version: Full screen music and music OSD
HI Guys,
Loveeeeee this Skin. Clean and fast!
Are the any hacks / ways of making music play full screen when you select a track or album to play automatically? Like other skins.
Also is the any way to make the OSD always display when music is playing?
(2019-05-11, 15:00)akhems Wrote: [ -> ]HI Guys,
Is there a skin I can try as an example? I can then investigate.
(2019-05-11, 15:32)Bumpaneer Wrote: [ -> ]
Sure!
Titan has both features.
Thanks dude!
(2019-05-11, 17:28)akhems Wrote: [ -> ]
Sure!
Thanks dude!
Which version of Titan?
(2019-05-11, 21:44)Bumpaneer Wrote: [ -> ]
(2019-05-11, 15:32)Bumpaneer Wrote: [ -> ]Is there a skin I can try as an example? I can then investigate.
Sure!
Thanks dude!
Any of them i believe but i know for a fact its on the latest one and the Krypton version.
The option will be present in the next release, probably in a week or two.
https://github.com/bumpaneer/skin.unity/...d984f7a3bb
The changes are listed above if you want to make the modifications yourself.
(2019-05-12, 14:53)Bumpaneer Wrote: [ -> ]The option will be present in the next release, probably in a week or two.
Thank you so much!
