Hi, I seem to have a big issue personally when using Leia version of Kodi. When I play a Video or Video Stream through a Widget. It loads up the "Video Resolving" Window like Normal and the Stream starts to play, but then it keeps reloading and reloading the Stream and gets stuck in an endless loop. The only way to get out is if you press cancel while the loading window pops up, then it stops looping and streams like normal. Ive been watching the exact same streams from the same addon for years. I had no issues on Krypton, but on Leia, I am having this issue. I have no idea if its a Leia, Skin, or Addon issue, but I am trying to find a way to resolve this. Thanks.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Hello, here is my log file. It says that its too large for even Kodi Paste Site, and Paste Bin so here is a Google Drive Link. I have replicated the issue 2 times. I have no idea where to look:
https://drive.google.com/file/d/1Ip27DBC...sp=sharing
I also can provide a short video of my problem if need be, just to show you visually what exactly is my issue. Thanks.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
https://paste.kodi.tv/bibuwizoqa.kodi
Here. I dupicated the error on one Stream for this example, but this happens to plenty of them. Streams that load through Widgets, will keep reloading until I force it to stop, and then it works fine.
