2019-05-21, 13:44
Dear all,
I noticed a significant change in how the database table streamdetails in Kodi 18.2 is being used. I use Kodi with a central MySQL DB (MariaDB on a QNAP device).
Prior to 18.2 all available streams of a media file have been stored in the table streamdetails. Now, only the video and one (the last used after playing the file) audio stream will be stored in streamdetails. No subtitles and no additional audio streams are present for files being scrapped and played by Kodi 18.2. If you are used to have video files with several audio streams and subtitles, this is anoying, especially when you use some self developed code to query those information from the database.
Furtermore the aspect ratio is set to "0" for such files in streamdetails. There is another thread dealing with that problem.
I can't believe, that this is a planned feature, so I asume a new bug in 18.2.
Cheers,
Zap
Cheers,
Zap
