Full Version: System menu disabled on Raspberry Pi
Relatively new to Kodi.
After some playing around and testing, and using Confluence as my preferred Skin, I wanted to have my setup as a dedicated Music Player.
For that I wanted the interface to be as minimal as possible, so I disabled all menu options apart from 'Music', as I won't be using those other options (TV, Movies, Games, Weather etc)
But I also disabled 'System'.
Hmmm, now that is totally inaccessible. I can't seem find anything on this forum related to fixing this. There's some info on modifying files on Windows etc, but if I plug my SD card in my PC, I don't see any of those files that need to be edited.
Any way to get the System option back?
And is there any way to have this linked to a keyboard shortcut, so if I still want to disable the menu option, it would still be available, but just not visible?
Many thanks.
Cheers,
Stefan
(2019-05-25, 00:47)Karellen Wrote: [ -> ]https://forum.kodi.tv/showthread.php?tid=343997
Thanks. I did see that one, but as I said in my post, that refers to an install on Windows.
I have a Raspberry Pi with LibreElec/Kodi on an SD card, and if I put that SD card in my computer (win10) I do not see any of those files.
All I have is a folder called 'Overlays' and .dtb files and some others. No 'Settings.xml' or anything.
I don't use LibreELEC, but looking at the wiki it states the userdata folder is in /storage/.kodi/userdata/
https://kodi.wiki/view/Userdata
If that is of no help others will need to advise.
Maybe @Hitcher can consider adding a shortcut to the shutdown menu?
(2019-05-25, 00:57)Stefke Wrote: [ -> ]
What happens if you open an explorer window on your pc and stick:
\\LibreELEC
in the address bar?
If you see a 'Userdata' share you can follow the instructions in Karellen's link.
(2019-05-25, 01:57)trogggy Wrote: [ -> ]
\\LibreELEC
in the address bar?
Both the method of \\LibreELEC and the method of accessing via Samba worked. Thanks!
So, was able to restore without having to do a full install again.
Still keen to know if there's a way to disable all menu options from main view apart from Music, but have others like Add-On and System accessible another easy way (via keyboard shortcut?)
Cheers,
Stefan
https://kodi.wiki/view/Keymap
https://kodi.wiki/view/Keymap#GUI_built-in.27s
xml:
ActivateWindow(settings)
xml:
ActivateWindow(addonbrowser)
