2019-05-26, 04:06
I have a Tanix TX9 Pro box with Android 7.12 attached to a Samsung NU7100 series TV. This box has a 912 AmLogic CPU. It came with a version of Kodi 17 that worked very well until I came up against some DRM issues on Australian FTA. After some reading I decided to update to Kodi 18.2 to get the DRM ability knowing that the resolution switching would be lost. The loss of switching is not an issue as I am only interested in 50hz content.
After installing 18.2 I see that the DRM issue has indeed been solved but I am stuck with a Whitelist with only 1920x1080 60Hz. There is no option to add to the Whitelist, either. It seems that in my research I misunderstood the ability with no switching. I thought I could choose a single resolution and stick with it, but it seems that is not the case. To remedy this I have tried to edit GUIsettings.XML whitelist and resolutions to 1920x1080 50 Hz while having the TV box set to a 3840x2160 50Hz or 1920 x 1080 50Hz resolution and Kodi still starts with the GUI Whitelist showing 1920x1080 60Hz. So They Whitelist data must be overriding the GUIsettings.xml or that data is stored in more than one location.
So I have a couple of questions:
1. I see that the whitelist gui resolution is white font. If I click on it it becomes green font... What is the significance of this font colour change?
2. I am happy with the box in general. Having said that, can anyone offer me a solution to have either 1920x1080 or 3840x2160 50HZ and DRM working? If I need to go back to a previous Kodi install, I am happy to do that.
Thank you in advance.
