Full Version: Scraping Errors
So, I did wipe and rebuild of my config when the Leia.2 version was released. Overall, all is good, but I'm having some odd scraping.
For example, Attack On Titan (the anime) will alternately decide to scrape as either Attack on Titan Junior High, or Attack on Titan Lost Girls.
Lost Girls is actually just a couple specials, that according to tvdb should be just part of regular Attack On Titan: https://www.thetvdb.com/series/attack-on-titan
I have no NFO files in the folders. As near as I can tell they're named correctly, and they're named the same way, and in the same file structure as they were before I did the database reinstall with the new version:https://paste.kodi.tv/urayifuxal
I also have the same problem with the series "Underground": https://www.thetvdb.com/series/underground
Again, no NFO file. But for some reason, the scraper is completely determined that this should is actually Tokyo Underground: https://www.thetvdb.com/series/tokyo-underground
Any thoughts? Any good way to just plain force it?
Tried refreshing the info and selecting from the list?
Also check https://www.themoviedb.org/ as the default scraper isn't TVDB anymore.
(2019-05-28, 07:00)Hitcher Wrote: [ -> ]Tried refreshing the info and selecting from the list?
Yeah..that may have been my problem. While waiting for a response I checked my setup again and it looked like I was set to use The Movie Database. I'm recsanning now but I think things may be worked out.
