can someone make a plugin of this site
http://www.radiocast.nl/ ?
it's a popular dutch podcast website
i don't know if someones also does foreign sites,but i will appreciate that.
I'll have a look at these for you tonight...can't read dutch but if I can find the RSS feeds I should be able to sort you out with a working plugin for them (Well really credit goes to Hagen who's written a podcast plugin already, all I'll be doing is tweaking the OPML files about a bit so that it points to your podcast of choice. Quite straight forward really
thanks TheBoxMan if you need help with the dutch you can pm me,
i have also another request
for a dutch tv guide
http://gids.in1woord.nl/
this channels are live stream that i watch on my xbmc on tv
so it would be appreciated to make a plugin/script of this.
Hey bro,
I thought you were just wanting a site with a few podcasts
My skills aren't up to doing a whole directory yet.
Anyway I've been through quite a few of them and got the data. I'm ready to work on an OPML, however I don't have enough free time these days to manually go through them all.
Are there any podcasts you *specifically* want and I'll make sure I add them?
It would be easiest if you could post the feed URL up here
Leastways that should at least keep you going until someone way better than me can code a plugin for the full site. (Really all credit for what I'm doing belongs to Hagen, I'm just doing the dogs body bit - he wrote the clever bit - all I'm doing is changing the OPMLs.)
Well someone writing a full plugin would find it much easier and wouldn't need to do them all.
unfortunately, as best I can see, there's no rss feed containing the rss feeds of the podcasts themselves (or have I missed that due to not speeking dutch?) hence I'm going through them one by one....
Will add the ones you've suggested now then grab some/all of the top 40.
on the left of the website there is a search engine .
( podcast zoeken ) is podcast search.
don't' think it's rss,but i don't know .i don't have knowledge of those things.
+ on the top you'll see : ( vinden luisteren,abonneren 1 ) there you can go to
( Categorieën ). this is the categories section.
maybe this helps you
tikkiew Wrote:you know this script http://code.google.com/p/xot-uzg/ of the website http://www.uitzendinggemist.nl/
i looks to me like a similar search engine but like i said.
i don't have knowledge of these things
Someone coding a plugin from scratch would be able to use the categories section and just scrape the site for the rss feed addresses. Unfortunately I'm not anywhere near good enough to do that right now (when I get a break from continuous coursework I'll read up) all I'm really able to do right now is collect the rss feeds manually (which will take ages) so I'll just get a selection for you - at least it should get you listening to your favourate ones.
As I say the bit I'm doing is relatively easy. Just takes a while.
If the site had used the same kind of system as is used to distribute podcasts to deliver a list of feeds (that's to say rss) I could have just added the one feed that would have contained all the others. Unfortunately they don't so I'll have to do some plodding.
As I say the credit for all of this really belongs with hagen. He did the clever bit.
all of your favourates are added btw, I'm just dotting through the top 40 right now picking some selections. When I'm done I'll post it up for you. Hopefully tonight or tomorrow I'll upload for you
Here you go:
http://rapidshare.com/files/126863049/DutchPod.rar.html
That's 20 of them. Let me know any others you want added and I'll update it.
I've a feeling a couple of them may be video feeds. If so you can add the plugin as a video as well and it should work.
Credit goes to Hagen really, I'm but the dogsbody
can't try it right now. i will try it later tonight.
i see the opml file seems easy to add podcast myself if i want more.
yeah thanks it works .and i can insert podcast by myself
but this request was not based solitary for myself.
in my mind it was also based for all the dutch xbmc users.
there is also a dutch xbmc download site .will ask if they put this plugin there.
i also ask contact owners of website if they can make search rrs like
you said TheBoxMan.but they didn't respond yet.
so if someone can make a plugin from the whole site
http://www.gespod.nl
it would be great.
guess i have to wait when Voinage can make this for me
i am know number 30 in his to do list.
