Full Version: Kodi crashes when accessing Chorus2 web interface
Hello,
kodi crashes occasionally when accessing Chorus2 version 18.x-2.4.6 web interface via browser.
To reproduce the crash:
    (re)Start Kodi
    Accessing http://kodiserver:8080/#movies/recent
    Kodi crashes
    You have to do this n times, because kodi crashes only occasionally.
debug log
syslog
If kodi crashes it will create a crashlog at your home dir. Please provide that as well. To get more infos it might also be necessary to install gdb before reproducing the crash.
(2019-05-30, 22:45)DaVu Wrote: [ -> ]If kodi crashes it will create a crashlog at your home dir. Please provide that as well. To get more infos it might also be necessary to install gdb before reproducing the crash.
Here comes the crashlog:
crashlog
I'm using the same OS and the same Kodi version here and no matter how often I refreshed the page, I cannot reproduce your issue. I tried refreshing and calling that link for about 30+ time and Kodi doesn't crash for me. Not saying that you are wrong. Just saying that I can't reproduce it.
A dev has to look at the crashlog. Thanks for that, btw.
(2019-06-03, 05:05)DaVu Wrote: [ -> ]I'm using the same OS and the same Kodi version here and no matter how often I refreshed the page, I cannot reproduce your issue. I tried refreshing and calling that link for about 30+ time and Kodi doesn't crash for me. Not saying that you are wrong. Just saying that I can't reproduce it.
To reproduce the issue, you have to do the following: start kodi, login into web interface,  calling the link, restart kodi, login into web interface, calling the link  and so on. It only happens at the first click after a kodi start/restart.
Thanks for your effort!
(2019-06-03, 10:00)neovenex Wrote: [ -> ]
bump
Crashlog is already gone, nothing to bump.
Sorry: Could you post the crashlog once more and make it "available" a bit longer?
Here comes the log:
crashlog
Thanks much!
