Full Version: New items not added to library
(2017-12-05, 08:29)Karellen Wrote: [ -> ]It looks like your naming is ok, as far as I can tell.
We will need to look at the Debug Log to see why Kodi is skipping them
  1. Go to Settings>System Settings>Logging then enable Debugging mode. Should be the first option
  2. Restart Kodi
  3. Replicate the problem. Run an Update Library.
  4. Upload the results to https://pastebin.com/ or https://paste.ubuntu.com/ and post the link back here.
I have recently noticed this issue happening as well. It seems to happen with everything *new* that I add to library. Usually, I'll manually scan to library only the new items. It has failed every time, except a couple days ago, and I cannot recall what I did to make it successfully scan those items.
I have tried updating my scraper add ons, and that fails constantly, no matter what it is, including all dependencies. (I I should also note here, that I cannot delete the Addons27.db file in an attempt to clean up the database for my add ons)
Here is my log result. Please advise? Thank you in advance!
https://paste.ubuntu.com/p/FzCNgcqRZp/
@DethReaper76
I have split you out of that thread as that was for Android and you are on Windows.
I have moved you to the correct forum - Metadata Scrapers.
Have a read of this ... https://forum.kodi.tv/showthread.php?tid=336969
You have provided the log (thanks for that), can you let me know the names of the tv show or movies that are not scraping. I have had a quick look at the log and it is quite large, so it would be easier if you tell me a couple of names.
I see this does not scrape... Jaycee Dugard - In Her Own Words
But the correct name is... Captive for 18 Years: The Jaycee Lee Story (2009) https://www.themoviedb.org/movie/450143-...uage=en-US
You have... Music That Wants Your Soul 2.0 (2012)
But should be... Music That Wants Your Soul (2012) https://www.themoviedb.org/movie/320171-...uage=en-US
Seem to be a lot of shows that are named incorrectly. Even looks like you have some tv shows mixed in with movies that won't work.
I'll wait until you point me to the correct titles.
