Hi.
Is it possible to export the settings of TMM 3.0 and import them into a fresh installation? My OS is Linux (Ubuntu).
Roberto
you only need to copy the .json/.conf files from the tmm/data folder over to the new installation
(2019-06-03, 07:48)mlaggner Wrote: [ -> ]you only need to copy the .json/.conf files from the tmm/data folder over to the new installation
Is it possible to use the settings from GUI on command line?
the settings are the same (for gui an cmd version).
but maybe the paths differ on different machines (data sources)
It would be greatly appreciated if this advise on how to export (backup) user settings could pop up --or be otherwise visible-- in the UI.
