(2019-06-09, 20:17)flavict Wrote: [ -> ]@Gade
with 11.2.41 everything under TV is messed up. TV guide have no description. TV recording is blank.
Thanks for reporting.
Some copy/paste errors found their way into 11.2.41. :-)
I have just pushed a new version (11.2.42) to my development repo.
Can you confirm that the issues are fixed?
Gade
Would like to confirm...if 11.2.42 was available in your dev repo. Latest versuin still 11.2.41 ;o)
Strange.
11.2.43 pushed to the repo.
I tested with one Windows machine, which automatically updated to the latest dev version.
edit: I did it on an other Kodi that I have and it worked. Confirming that all TV stuff is back.
will try to troubleshoot my other Kodi.
weird...
Now update 11.2.42 is available. But when updating I am getting an update failed.
(2019-06-09, 12:15)Gade Wrote: [ -> ]@ClausMM: Did you see my reply?
Yes thank you. I think I described the problem inaccurately.
After I installed Amazon, as described in "Netflix_and_Amazon_add-ons.pdf", the "CHANNELS" were empty.
Everything was OK before the Amazon installation.
With "Esturay" everything is OK after the Amazon installation (see pdf file)
Netflix and Amazon add-ons (2).pdf
Hi Claus.
Ahaaa, maybe now I get it. :-)
So the channels from Amazon addon are empty?
Do you access the channels content the same way in Estuary and Rapier?
I noticed that in Estuary you look at "All channels" and in Rapier you look at a channel group called "ClausMM".
Is that channel group empty?
(2019-06-09, 12:15)Gade Wrote: [ -> ][font][font]@ "ClausMM": Hast du meine Antwort gesehen?[/font][/font]
[font][font]Ich habe mich lange nicht gemeldet. [/font][font]Mit der Version 11.2.44 ist der von mir beschriebene Fehler nicht mehr vorhanden. [/font][/font]
[font][font]Amazon Add-On funktioniert jetzt, danke.[/font][/font]
Hi Claus.
Thanks for getting back.
Great that everything works as expected now.
I'll mark this thread as solved.
