Hello
after installing "Netflix and Amazon Add-ons" (see description)
is the screen "CHANNELS" and "RECORDING" reproducibly empty (see picture)
Can you help me or do I have to go back to the "Esturay" interface ?
Best regards ClausMM from Berlin
Netflix and Amazon add-ons.pdf
screen "CHANNELS" empty
Hi Claus.
Your screenshot is from live tv?
Netflix and Amazon are not PVR addons.
To get live tv channels you need a PVR addon:
PVR (wiki)
To access the Netflix addon, go to Videos > Amazon.
You can even integrate movies and tv shows from Netflix with your regular libraries.
EDIT: You will get the same result in all skins.
hi Gade and thanks for Rapier.i used from jarvis.working perfect.about the netflix add-on:very good but in video osd the tv series poster missing.is empty.i know is not a big deal but in estuary working.can you fix in the future?
(2019-06-08, 12:22)sinclair65 Wrote: [ -> ]hi Gade and thanks for Rapier.i used from jarvis.working perfect.about the netflix add-on:very good but in video osd the tv series poster missing.is empty.i know is not a big deal but in estuary working.can you fix in the future?
Hi sinclair65.
Thanks for your support.
I would really like to fix it.
Please post a screenshot from Rapier and from Estuary.
sinclair65
You seem to be having problems with images. Follow this guide...
If the image is on your computer, then use button 19.
If the image has already been uploaded to a public image hosting site, right click the image and select
Copy image location then use button 14 and paste the link
Thanks a lot, sinclair65.
This helped me identify the problem.
It should all be fixed now and will be included in the next development update.
I have just pushed v11.2.41 to my development repo:
https://kodi.wiki/view/Add-on:Rapier#Dev...Repository
Please let me know if everything works as expected.
Gade
Looking at the first image, I think you have the same problem that Estuary had a little while ago...
15891 (PR)
The TV Show title and the Episode title are reversed. Is this intentional?
(2019-06-09, 09:34)Gade Wrote: [ -> ]Thanks a lot, sinclair65.
I have just pushed v11.2.41 to my development repo: https://kodi.wiki/view/Add-on:Rapier#Dev...Repository
Done.thanks Gade is better now.working.
Great it's working now.
Thanks for reporting the issue.
Gade
with 11.2.41 everything under TV is messed up. TV guide have no description. TV recording is blank.
Had to revert back to 11.2.35.
