Full Version: Can tMM show before renaming only the folders / files which will be renamed?
When "Renaming" is activated and you want to rescrape all of the movies, e.g. 200, in your movie folder, can tMM show before renaming only the folders / files which will be renamed?
When a movie automatically is scraped and renamed incorrectly there does not seem to be a way to check that after renaming instead of before to being able to check the file name against the scrapted movie.
There is a renamer preview - you could use that instead of automatic rename
Where can I find it?
Ever manually renamed a movie?
It's right below the normal renaming!
PS:
we have a menu bar which shows all actions - just read...
and as a windows user, a right click should be the first thing to try...
Quote: It's right below the normal renaming!
This one?
The menu bar at the bottom on the right?
Yes, use the dry run
