Full Version: Same Part of Library Re-scraping on each start
Each time I start up I start up Kodi on the Xbox One it rescrapes the same items in the video library.  It looks like it is a database conversion issue but wanted to post it to see if anyone else can spot something.  https://paste.kodi.tv/igowajikeb.kodi
2019-06-01 20:05:58.762 T:5336 ERROR: SQL: [MyVideos116.db] SQLite error SQLITE_ERROR (SQL logic error or missing database)
Query: CREATE UNIQUE INDEX ix_actor_link_1 ON actor_link (actor_id, media_type, media_id) (SQL logic error or missing database)
Apparently your video database is broken, corrupted or otherwise incapacitated.
To keep it simple: delete the MyVideos116.db file, and rescrape your video collection.
When all of that is done, make backups of your database file(s).
(2019-06-11, 08:12)Klojum Wrote: [ -> ]2019-06-01 20:05:58.762 T:5336 ERROR: SQL: [MyVideos116.db] SQLite error SQLITE_ERROR (SQL logic error or missing database)
Do you mean backing up the library like this https://kodi.wiki/view/HOW-TO:Backup_the_video_library or the *.db file itself?  I actually deleted and rebuilt the library when I had this problem the first time around 3 months ago and within a few days it got corrupted again so I wanted to make sure I knew the best way to keep a backup of the database in case it corrupts itself again.
When you use only the default local SQLite database files, then you can simply make a copy of that .db file and keep it in a safe location.
Having another corrupted database so soon again is a bit odd. Check your HDD/SDD for disk errors.
