Full Version: Configure multiple game controllers in Kodi
Hi guys,
I have two xbox wireless controllers setup in windows 10. I am wondering how to set these up in Kodi. I only found the option to configure one. Could you please advise how to do that? Also google was not giving me any details on that issue.
thanks.
(2019-06-11, 17:57)realshadow Wrote: [ -> ]Hi guys,
thanks.
Currently it is not possible. If both controllers are identical, last time I tried (Kodi Jarvis...) Kodi accepted input from both controllers, however I'm not sure if Kodi Leia will do the same or just accept commands from the first controller. Note that the first controller is chosen by the OS, not by Kodi.
In addition, note that there is a bug that prevents to use a custom XML to configure the joystick. You must delete the system-wide default config first.
I dodge Kodi and just bind keyboard keys to my controllers but I recommend that you try to get it sorted in Kodi first because Xpadder can complicate matters for you.
1. Xpadder to bind keys to buttons
2. Configure Autoprofiles in Xpadder to watch for Kodi
3. Disable controller support in Kodi
