Full Version: How to use Nitrokey Storage USB stick with a remote for PIN entry
I am trying to use a Nitrokey Storage encrypted USB stick with Kodi on a media device (Vero 4K with OSMC).  When the Nitrokey is inserted into a usb slot, on a laptop for example, I get a PIN entry popup and may proceed to access the device assuming the required public key is installed.  With the Vero 4K media device I can SSH in order to install the public key but for normal usb use and convenience I can only use a remote.
Is there an add-on or similar for Kodi which will prompt the entry of the PIN number and then allow the encrypted usb device to be accessed as normal but only using the remote.
