Full Version: TMM v3.0.1: org.tinymediamanager.thirdparty.KodiRPC => Connection timed out
Hi friends,
I use TMM version 3.0.1
I try to set up "Settings => General => External Devices" Kodi / XBMC.
IP-Address, HTTP-Port, TCP-Port (9090), user and password are entered correctly.
In the settings on the Kodi also all settings for external access are set.
I can access it via a web browser (client like the same as TMM) and i can access it from anywhere with Yatse on my mobile phone.
What could be the mistake?
Enclosed an excerpt from the log:
Quote:2019-06-14 09:33:48,002 INFO  [Thread-23] org.tinymediamanager.thirdparty.KodiRPC:471 - Connecting...
2019-06-14 09:35:55,661 ERROR [Thread-23] org.tinymediamanager.thirdparty.KodiRPC:475 - Error connecting to Kodi
org.tinymediamanager.jsonrpc.io.ApiException: Connection timed out (Connection timed out)
    at org.tinymediamanager.jsonrpc.io.JavaConnectionManager.connect(JavaConnectionManager.java:105)
    at org.tinymediamanager.thirdparty.KodiRPC.lambda$connect$0(KodiRPC.java:472)
    at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.net.ConnectException: Connection timed out (Connection timed out)
    at java.base/java.net.PlainSocketImpl.socketConnect(Native Method)
    at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
    at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
    at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
    at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:403)
    at java.base/java.net.Socket.connect(Socket.java:591)
    at java.base/java.net.Socket.connect(Socket.java:540)
    at org.tinymediamanager.jsonrpc.io.JavaConnectionManager.connect(JavaConnectionManager.java:93)
    ... 2 common frames omitted
BR
Werner
Please create some more logfiles: Menu->tools->bugReport -> ZipFile.
Upload it somewhere.
Timeout usually means "not reachable", be it a firewall, or wrong IP.
(2019-06-14, 10:41)myron Wrote: [ -> ]Please create some more logfiles: Menu->tools->bugReport -> ZipFile.
In the "tmm.json" i have overwrite the data of my kodi host and userdata.
Here is the Link to the the ZipFile
I can exclude firewall and wrong IP address.
I will also try it at home on the local network - but can post the result on Monday
thx an br
Werner
At home on the local network it's the same problem.
