2019-06-18, 01:51
I'm streaming flawlessly from locally stored video via SMB on Kodi 18.2 running on an Amazon Firestick v2. Since upgrading to Kodi v18, my AVI's "stutter" on playback - the video looks like it's playing at under 5 frames per second. On a hunch, I used ffmpeg and converted one of these stuttering videos to mp4 - no other changes. Streaming this mp4 results in normal, smooth playback.
I have 2 Firesticks, both with Kodi 18.2, and both Firesticks exhibit this saem behavior.
The AVI that stutters has this video:
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 42 min 18 s
Bit rate : 955 kb/s
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.174
Stream size : 289 MiB (83%)
Writing library : XviD 1.1.0 (UTC 2005-11-22)
The converted video, that plays correctly, has this video:
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 570 kb/s
Width : 624 pixels
Height : 352 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.104
Stream size : 172 MiB (81%)
Writing library : x264 core 155 r2901 7d0ff22
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
I have no desire to re-encode my entire library. Any help would be appreciated.
Codec ID : XVID
Bit rate : 955 kb/s
Width : 624 pixels
Height : 352 pixels
Color space : YUV
Bit depth : 8 bits
Format : AVC
Codec ID : avc1
Bit rate : 570 kb/s
Width : 624 pixels
Height : 352 pixels
Color space : YUV
Bit depth : 8 bits
