2019-06-20, 17:04
2019-06-20, 17:11
The list view already shows the cover.
2019-06-20, 18:01
Yes i know, but i need it in the view "media info".
Sorry i forgot to wrote that.
2019-06-20, 19:27
For Movies you need to change https://github.com/xbmc/skin.confluence/....xml#L1382
from
However that image control is set to scale (which for a cover would zoom in so width of cover fits exactly thus chopping to & bottom off) so in order to display the full cover you also need to change https://github.com/xbmc/skin.confluence/....xml#L1380
from
That would do just movies, for tv shows and ordinary videos you would also need to change
https://github.com/xbmc/skin.confluence/....xml#L1392
https://github.com/xbmc/skin.confluence/....xml#L1394
from
toxml:<texture background="true" fallback="Fanart_Fallback_Small.jpg">$INFO[ListItem.Art(fanart)]</texture>
xml:<texture background="true" fallback="Fanart_Fallback_Small.jpg">$INFO[ListItem.Art(poster)]</texture>
from
toxml:<aspectratio>scale</aspectratio>
xml:<aspectratio>keep</aspectratio>
2019-06-20, 19:55
Absolutely Perfect!!! Big Big Thanks!
