Full Version: Kodi doesn't scrap some movies titles
Around 1/5 of the movies are not named when I scan. I tried with TMDB, universal scraper, IMBD... I am totally sure that I have the source well set, the network config also, the addons are updated, the titles well written, only works when I parsed .nfo files, but so much work to do one .nfo for one movie...
The message that scrapper says is:"loading details of the movie 0%. . . . . . . Not info was found"
Anyone can help me with that please?? Thank you
Pd. Im using 18.2 in raspbian
@javii77
Have a read of this... https://forum.kodi.tv/showthread.php?tid=336969 particularly item 1d
If nothing there helps, provide the info as detailed in part 2
Moved to metadata scrapers
(2019-06-21, 01:39)Karellen Wrote: [ -> ]@javii77
Thank you very much!!!
You save my day, I tried everything...
It was the video tag (1d)
Solved Smile
@javii77
Great!! A quick and easy fix. Smile
I'll mark this thread solved.
