2019-06-21, 15:15
I have been using Kodi 'Krypton' for quite a while, on a pretty basic level. I have noticed that the assigning, or routing, of surround sound channels seems to be incorrect: when viewing a 5.1 channel video, I hear the audio that should be coming from the side (5.1) speakers coming from the rear (7.1) speakers. I checked the configuration of my audio device in Windows (10, 64-bit), and as the configuration test runs, audio comes from the physical speakers as per the on screen diagram (Left, Right, Centre, Sub Surround Left, Surround Rear Left, Surround Rear Right, Surround Right) so I know my speakers and OS are configured correctly (or at least configured the same). I figured this may be a glitch/bug, so downloaded and installed 'Leia' but have the same result.
Interestingly I get the similar results with VLC. When DirectX output module is configured for 7.1 (8 channels for the wav out module), the surround channels from a video with 5.1 audio are routed to all the surround speakers (side and rear). When DirectX is configured for 5.1 (6 channels for the wav out module), the side surround channels audio is heard through the rear speakers. An VLC update (3.0.7.1 - 64-bit, configured as 7.1 channels) sees the same results I'm getting in Kodi - side speakers audio being routed through to rear speakers, no audio to side speakers.
Is there a work around for this (apart from re-wire or relocate the speakers each time I use Kodi)? Does Kodi use VLC for playback (or the same code), or is there a DirectX configuration that needs tweaking?
