Full Version: Helo with visible condition for container in different window
I'm trying to create a window that is displayed when Kodi is loading addons. This will prevent my wife from clicking on things when Kodi is initializing. The window has slide show of fanart that is displayed while Kodi is loading, and is supposed to display button "Press OK to Continue" message when addons are loaded. The code I have does not work as it displays the the "Press OK to COntinue" button before the addons are completed loading. I referred to code in home.xml for displaying the addons section in the skin.
Here is my code for my "Press Ok to continue" button. Again, this is in a different window. I am calling only of the
<?xml version="1.0" encoding="UTF-8"?>
<window id="1281">
     <onload>SetFocus(108)</onload>
        <defaultcontrol always="true">108</defaultcontrol>
        <previouswindow>ActivateWindow(1281)</previouswindow>
    <controls>
        <include>Setupbackground</include>
        <control type="multiimage" id="102">
                    <left>0</left>
                    <top>0</top>
                    <width>100%</width>
                    <height>100%</height>
                    <imagepath>http:///fanart/</imagepath>
                    <timeperimage>4000</timeperimage>
                    <randomize>false</randomize>
                       <fadetime>0</fadetime>
                </control>
            <control type="button" id="108">
                    <visible> Integer.IsGreater(Container(8400).NumItems,0) </visible>
                    <animation effect="slide" start="10" end="0" >WindowOpen</animation>
                    <include>OpenClose_Right</include>
                    <description>Next button</description>
                    <font>font37</font>
                    <align>center</align>
                    <posy>950</posy>
                    <posx>0</posx>
                    <width>1920</width>
                    <height>90</height>
                    <texturefocus colordiffuse="DA8C46B9">colors/white.png</texturefocus>
                    <texturenofocus colordiffuse="DA8C46B9">colors/white.png</texturenofocus>
                    <focusedcolor>white</focusedcolor>
                    <textcolor>white</textcolor>
                    <onup>108</onup>
                    <ondown>108</ondown>
                    <onleft>108</onleft>
                    <onright>108</onright>
                    <label>Press OK to continue.</label>
                    <onclick>ActivateWindow(home)</onclick>
            </control>
            <control type="button" >
                <animation effect="slide" start="0,0" end="4000,4000" time="0" reversible="false" condition="Control.IsVisible(108)">Conditional</animation>
                    <font>font37</font>
                    <posy>950</posy>
                    <posx>0</posx>
                    <width>1920</width>
                    <height>90</height>
                    <label>Loading Content...Please Wait.</label>
            </control>
                       <control type="image">
                           <animation effect="slide" start="0,0" end="4000,4000" time="10" reversible="false" condition="Control.IsVisible(108)">Conditional</animation>
                        <description>Busy animation</description>
                       <top>965</top>
                        <posx>30%</posx>
                        <width>60</width>
                        <height>60</height>
                        <texture colordiffuse="button_focus">spinner.png</texture>
                        <aspectratio>keep</aspectratio>
                        <animation effect="rotate" start="360" end="0" center="auto" time="3000" loop="true" condition="true">conditional</animation>
                       </control>
    </controls>
</window>
I'm using code from the home.xml which determines when addons will be visible
<control type="group" id="8000">
                    <visible>String.IsEqual(Container(9000).ListItem.Property(id),addons)</visible>
                    <include content="Visible_Right_Delayed">
                        <param name="id" value="addons"/>
                    </include>
                    <control type="grouplist" id="8001">
                        <include>imagefade</include>
                        <control type="label">
                        <top>230</top>
                        <left>50</left>
                        </control>
                        <ondown>ActivateWindow(1270)</ondown>
                        <include>WidgetGroupListCommon</include>
                        <include>spacehor1_Apps</include>
                        <include content="WidgetListCategories">
                            <param name="widget_header" value="$LOCALIZE[31148]"/>
                            <param name="list_id" value="8900"/>
                            <param name="visible" value="Integer.IsGreater(Container(8100).NumItems,0) | Integer.IsGreater(Container(8200).NumItems,0) | Integer.IsGreater(Container(8300).NumItems,0) | Integer.IsGreater(Container(8400).NumItems,0) | Integer.IsGreater(Container(8500).NumItems,0)"/>
                            <param name="addon_submenu" value="true"/>
                        </include>
                        <include content="WidgetListSquare" condition="System.Platform.Android">
                            <param name="content_path" value="androidapp://sources/apps/"/>
                            <param name="widget_header" value="$LOCALIZE[20244]"/>
                            <param name="widget_target" value="programs"/>
                            <param name="sortby" value="lastused"/>
                            <param name="sortorder" value="descending"/>
                            <param name="list_id" value="8400"/>
                            <param name="fallback_icon" value="DefaultAddon.png"/>
                        </include>
                        <include content="WidgetListSquare">
                            <param name="content_path" value="addons://sources/video/"/>
                            <param name="widget_header" value="$LOCALIZE[1037]"/>
                            <param name="widget_target" value="videos"/>
                            <param name="list_id" value="8100"/>
                        </include>
                            <param name="content_path" value="addons://sources/audio/"/>
                            <param name="widget_header" value="$LOCALIZE[1038]"/>
                            <param name="widget_target" value="music"/>
                            <param name="list_id" value="8200"/>
                        </include>
                            <param name="content_path" value="addons://sources/executable/"/>
                            <param name="widget_header" value="$LOCALIZE[1043]"/>
                            <param name="list_id" value="8300"/>
                        </include>
                            <param name="content_path" value="addons://sources/image/"/>
                            <param name="widget_header" value="$LOCALIZE[1039]"/>
                            <param name="widget_target" value="pictures"/>
                            <param name="list_id" value="8500"/>
                        </include>
                    </control>
                    <include content="ImageWidget">
                        <param name="image_path" value="special://skin/extras/home-images/add-ons.jpg"/>
                        <param name="text_label" value="$LOCALIZE[31119]" />
                        <param name="button_label" value="$LOCALIZE[31118]" />
                        <param name="button_onclick" value="ActivateWindow(addonbrowser)"/>
                        <param name="button_id" value="8600"/>
                        <param name="visible" value="!Integer.IsGreater(Container(8001).NumItems,0)"/>
                        <param name="button2_onclick" value="Skin.SetBool(HomeMenuNoProgramsButton)"/>
                    </include>
                </control>
Your previouswindow control is wrong and you can't get a value from another window so this needs to be added to the home.xml.
(2019-06-23, 08:32)Hitcher Wrote: [ -> ]Your previouswindow control is wrong and you can't get a value from another window so this needs to be added to the home.xml.
I put it on the home.xml with visible tags. The screen does not close after the addons are loaded:
 <control type="group">
        <visible>Integer.IsLess(Container(8100).NumItems,1) | Integer.IsLess(Container(8200).NumItems,1) | Integer.IsLess(Container(8300).NumItems,1) | Integer.IsLess(Container(8400).NumItems,1) | Integer.IsLess(Container(8500).NumItems,1)</visible>
                    <left>0</left>
                    <top>0</top>
                    <width>100%</width>
                </control>
                    <animation effect="slide" start="10" end="0" delay="40000">WindowOpen</animation>
                    <font>font37</font>
                    <posy>950</posy>
                    <posx>0</posx>
                    <width>1920</width>
                    <height>90</height>
                    <onup>108</onup>
                    <label>Setup Complete...Press OK </label>
                    <onclick>Skin.SetBool(loading_delay))</onclick>
            </control>
                    <font>font37</font>
                    <posy>950</posy>
                    <posx>0</posx>
                    <width>1920</width>
                    <height>90</height>
            </control>
                       <top>965</top>
                        <posx>30%</posx>
                        <width>60</width>
                        <height>60</height>
                       </control>
    </control>
(2019-06-23, 15:54)james739 Wrote: [ -> ]
                    <left>0</left>
                    <top>0</top>
                    <width>100%</width>
                </control>
                    <font>font37</font>
                    <posy>950</posy>
                    <posx>0</posx>
                    <width>1920</width>
                    <height>90</height>
                    <onup>108</onup>
            </control>
                    <font>font37</font>
                    <posy>950</posy>
                    <posx>0</posx>
                    <width>1920</width>
                    <height>90</height>
            </control>
                       <top>965</top>
                        <posx>30%</posx>
                        <width>60</width>
                        <height>60</height>
                       </control>
    </control>
How can i make animation automatically open and close images after 40 seconds?
