Hey,
I've got a container set with static items as its content.
For some weird reason Kodi insists on focusing the second item in the container as default.
I can't use 'defaultfocus' attribute because it also consists of dynamic items and it doesn't seem to work in conjunction (if dynamic items are not added as content it still puts focus on second item).
To clarify, when testing this container with just changing content to plugin based/xsp based, its default focus is on the first item, so i'm not sure how an excerpt of the specific code can be helpful here, it seems more of a global issue...
Ideas?
No idea but was hoping you were working on this. Your Categories widget is my only widget that doesn't have the slim list on the left on startup. Just thought I would help out by bumping this to the top where someone who might know will see it.
i assume its multiple content.
May its focused the first 'visible' item.
did you test with
Quote:control.setfocus(**),0,absolute
(2019-06-26, 20:39)mardukL Wrote: [ -> ]i assume its multiple content.
did you test with
Yeah of course but I want to solve the root problem and not patch it. Also, I can't really use this method specifically since I don't know upfront which id the container will be assigned with...
(2019-06-26, 21:46)cartman.dos Wrote: [ -> ] (2019-06-26, 20:39)mardukL Wrote: [ -> ]i assume its multiple content.
did you test with
can you post a code snippet?
i assume that you have
<content>a</content>
<content>b</content>
in one container.
where content b is faster visible than a.
that is why b gets focused first.
but just thinking ;-)
other solution would a control.move(**,-1)
as onload action if possible
(2019-06-27, 03:38)mardukL Wrote: [ -> ] (2019-06-26, 21:46)cartman.dos Wrote: [ -> ] (2019-06-26, 20:39)mardukL Wrote: [ -> ]i assume its multiple content.
did you test with
in one container.
<include>StaticWidget_Categories</include>
<content sortby="$PARAM[widgetSortBy]" sortorder="$PARAM[widgetSortOrder]" limit="$PARAM[widgetLimit]" target="$PARAM[widgetTarget]">plugin://script.skin.helper.widgets/?action=browsegenres&mediatype=media</content>
The include definition is for example:
<content>
<item id="1">
<label>$LOCALIZE[31532]</label>
<thumb>bingie/categories/topratedmovies.jpg</thumb>
<property name="DBTYPE">category</property>
<property name="path">special://skin/playlists/topratedmovies.xsp</property>
<onclick>ActivateWindow(Videos,special://skin/playlists/topratedmovies.xsp,return)</onclick>
<visible>true</visible>
</item>
</content>
So the faster one is actually first, also for control.move I need an id upfront, unless I'm using something like sualfred's resetposition method, which i can provide a long list of possible ids, but still not ideal :/
