2019-06-25, 23:53
Hi, so with superfavorites basically dead at this point, i found EstuaryMOD v2 and its category menu is pretty great as you can make custom shortcuts. Normally i would make custom shortcuts in superfavorites and point a widget to that superfavorites folder but since SF has issues with leia atm, i wanted to see if there was a way to do the following
- Add Second Category section with vertical scroll options like custom widgets, lies between Top Categories and Widgets
- Fix padding on right side so it doesn't touch the edge
- Widget view just like regular category view
This would allow me to make custom menus and have everything like i want. If anyone has some hints how i could accomplish this i would massively appreciate it
