2019-06-26, 02:29
I have been unable to collect enough information for a proper bug report, but what I've found so far is interesting enough that I thought I'd see what everyone else thought.
The issue
On some videos that used to play fine, Kodi 18.2 will seem to play them, but no video appears.
What I've found
For as-yet unknown reasons, in the debug log on affected videos I get:
DEBUG: Visible Behind request: true
DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
This does not seem to be format or codec specific. Copying the video of affected files verbatim causes the problem to follow the video. Transcoding the video to the SAME CODEC with ffmpeg results in a playable file. I don't yet have any samples of affected files that can be shared (part of the incomplete nature of this report...)
The XBMC code that logs that message is in XBMCApp.cpp line 443.
It appears to be caused by either resuming from a screensaver or on playback start. The latter seems to apply equally to both the video that works and the video that doesn't. In addition, that may not be the code where the above "Visible behind request" gets triggered since in both the visible and invisible play the log immediately prior is not a DEBUG level log. Instead in both cases the log shows:
DEBUG: No whitelisted resolution matched
NOTICE: Display resolution ADJUST : 1920x1080 @ 60.000004 - Full Screen (16) (weight: -0.000)
The last section that seems to set this true is the onNewIntent section. This is a complex section but I never see the 'Got intent' log in debug so it doesn't seem to be triggered.
Later on in the logs, I see what appears to be an effect of the above "Visible Behind" issue:
DEBUG: Inhibiting OS screen saver
DEBUG: CVideoPlayer::SetCaching - caching state 2
DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
ERROR: CDVDVideoCodecAndroidMediaCodec::GetOutputPicture unknown index(-10000)
ERROR: Previous line repeats 14353 times.
Compare that to the working output from the same point:
DEBUG: CDVDVideoCodecAndroidMediaCodec:: width(512), height(384), stride(512), slice-height(384), color-format(259)
DEBUG: CDVDVideoCodecAndroidMediaCodec:: crop-left(0), crop-top(0), crop-right(511), crop-bottom(383)
DEBUG: CDVDVideoCodecAndroidMediaCodec:: Multi-Surface Rendering
DEBUG: CRenderManager::Configure - change configuration. 512x384. display: 512x384. framerate: 25.00.
What is a good way to find out why the below lines appear for some files but not others?
I realize this is somewhat incomplete info, but I'd appreciate any help.
Thanks,
-- Steve
The issue
What I've found
Thanks,
-- Steve
