Full Version: Check for Updates using command line
is there any way to check for updates using the command line? Or is there a Text file wäre i can read out the last released Version after TMM GUI was run?
I want to automate updates for my apps that are not installed using apt.
bf
Well, TMM auto-updates pretty self by using it.
You also can force an update by running the updater directly. (eg on a weekly basis)
But there's no method to check, if an update is available;
You have to check a named remote file, and compare it with a local one...
But why the need for a script, when TMM does this for you..?
