2019-06-29, 03:53
2019-06-29, 10:58
(2019-06-29, 03:53)sterned Wrote: [ -> ]I can do it through information on default Kodi but can't figure it out on Aeon mq8. I don't see a option to manage a title.
On mq7 when you select movie, you have to go in movie information (press I),click Reload, click Yes, in select movie screen click on manual and enter new movie name.
2019-06-29, 16:05
Its the same in Aeon MQ8
2019-06-29, 16:35
(2019-06-29, 16:05)Wanilton Wrote: [ -> ]Its the same in Aeon MQ8
Thanks it just wont show the other movie in the list. Saying philospers stone instead of sorecers stone.
2019-06-29, 16:54
(2019-06-29, 16:35)sterned Wrote: [ -> ]That's why @AleksandarLS said you have to go to "Manual". That will enable you to manually type in the film you want to find.(2019-06-29, 16:05)Wanilton Wrote: [ -> ]Its the same in Aeon MQ8
2019-06-29, 22:38
(2019-06-29, 16:35)sterned Wrote: [ -> ]Saying philospers stone instead of sorecers stone.They are both the same movie, but named differently depending on which country you live in.
If you want to change the name, then edit the Title through the Manage context menu
2019-06-30, 04:45
(2019-06-29, 22:38)Karellen Wrote: [ -> ]Will it change the poster etc.?(2019-06-29, 16:35)sterned Wrote: [ -> ]Saying philospers stone instead of sorecers stone.They are both the same movie, but named differently depending on which country you live in.
2019-06-30, 04:45
(2019-06-29, 16:54)E net Wrote: [ -> ](2019-06-29, 16:35)sterned Wrote: [ -> ]That's why @AleksandarLS said you have to go to "Manual". That will enable you to manually type in the film you want to find.(2019-06-29, 16:05)Wanilton Wrote: [ -> ]Its the same in Aeon MQ8
I did type it and the search just comes back with philosophers stone. Damn Brits!
2019-06-30, 05:07
(2019-06-30, 04:45)sterned Wrote: [ -> ]Will it change the poster etc.?Short answer... No. You need to do that manually. Kodi does not know which poster you want, so just allocates the most popular one.
Here is the entry at TheMovieDB... https://www.themoviedb.org/movie/671-har...uage=en-US Two ways to change the poster...
1. Go to Choose Art, then browse through the available posters, or
2. Find the correct poster at the above site, save it next to your video file and then apply the artwork through Choose Art. See image at bottom of page... https://kodi.wiki/view/Movie_artwork
(2019-06-29, 22:38)Karellen Wrote: [ -> ]If you want to change the name, then edit the Title through the Manage context menuWhat I said above, is different to what you are doing below.
(2019-06-30, 04:45)sterned Wrote: [ -> ]I did type it and the search just comes back with philosophers stone.
To clarify...
1. Scrape your movie into the library. Don't keep scraping, nothing will change and it will still have the title you don't want
2. Go to your library listing and highlight the movie
3. Call up the Context Menu
4. Select Manage
5. Select Edit Title
6. Edit the title to the one you prefer
Now to change the Poster...
1. Go the the Movie Information Screen
2. Select Choose Art
3. Select Poster
4. Choose a new Poster.
If you are not sure where to find these menus, see here... https://kodi.wiki/view/Basic_controls
2019-07-04, 14:27
(2019-06-30, 05:07)Karellen Wrote: [ -> ]got it thanks!(2019-06-30, 04:45)sterned Wrote: [ -> ]Will it change the poster etc.?Short answer... No. You need to do that manually. Kodi does not know which poster you want, so just allocates the most popular one.
To clarify...
4. Select Manage
3. Select Poster
