I try to move all kodi setting to samba share:
I make a script to mout /root/.kodi settings folder to smb folder.
run.sh
mkdir /mnt/kodi
mount -t cifs -o username=user,pass=1234,dir_mode=0777,file_mode=0777,vers=1.0 //192.168.0.198/kodi-data$/kodi /mnt/kodi
sudo ln -s /mnt/kodi /root/.kodi
kodi
I see files in my share created by kodi, but kodi won't start? Why?
Did you check the KODI LOG?
(2019-06-29, 11:13)lpt2007 Wrote: [ -> ]vers=1.0
Try version 2, smb1 has been deprecated because of too many network security weaknesses.
LibreELEC defaults to SMBv2, and so does Kodi.
(2019-06-29, 13:03)Klojum Wrote: [ -> ] (2019-06-29, 11:13)lpt2007 Wrote: [ -> ]vers=1.0
I try with vesr=2.0, but not working.
(2019-06-29, 11:33)ActionA Wrote: [ -> ]Did you check the KODI LOG?
Kodi log on first start when /root/.kodi is empty:
KODI starts but nothing on screen
2019-06-29 16:30:02.104 T:1902195296 NOTICE: -----------------------------------------------------------------------
2019-06-29 16:30:02.104 T:1902195296 NOTICE: Starting Kodi (18.2 Git:20190428-a94ccc8ba5). Platform: Linux ARM 32-bit
2019-06-29 16:30:02.104 T:1902195296 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-06-29 16:30:02.104 T:1902195296 NOTICE: Kodi compiled 2019-04-30 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-06-29 16:30:02.105 T:1902195296 NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98-v7
2019-06-29 16:30:02.105 T:1902195296 NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-06-29 16:30:02.105 T:1902195296 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2019-06-29 16:30:02.105 T:1902195296 NOTICE: ARM Features: Neon enabled
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://masterprofile/ is mapped to: /root/.kodi/userdata
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://envhome/ is mapped to: /root
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://home/ is mapped to: /root/.kodi
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://temp/ is mapped to: /root/.kodi/temp
2019-06-29 16:30:02.105 T:1902195296 NOTICE: special://logpath/ is mapped to: /root/.kodi/temp
2019-06-29 16:30:02.106 T:1902195296 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi_v7
2019-06-29 16:30:02.106 T:1902195296 NOTICE: Local hostname: local-kodi
2019-06-29 16:30:02.106 T:1902195296 NOTICE: Log File is located: /root/.kodi/temp/kodi.log
2019-06-29 16:30:02.106 T:1902195296 NOTICE: -----------------------------------------------------------------------
2019-06-29 16:30:02.106 T:1902195296 INFO: loading settings
2019-06-29 16:30:02.112 T:1902195296 NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-06-29 16:30:02.117 T:1902195296 ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
2019-06-29 16:30:02.294 T:1902195296 DEBUG: CSkinSettings: no <skinsettings> tag found
2019-06-29 14:30:02.318 T:1902195296 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-06-29 14:30:02.318 T:1902195296 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
2019-06-29 14:30:02.318 T:1902195296 WARNING: CSettingsManager: missing version attribute
2019-06-29 14:30:02.328 T:1902195296 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-06-29 14:30:02.328 T:1902195296 NOTICE: Default Video Player: VideoPlayer
2019-06-29 14:30:02.328 T:1902195296 NOTICE: Default Audio Player: paplayer
2019-06-29 14:30:02.328 T:1902195296 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-06-29 14:30:02.328 T:1902195296 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
Here a kodi.log whe I try to start kodi second time:
KODI stops with error: terminate called after throwing an instance of 'dbiplus:bErrors'
2019-06-29 16:39:41.713 T:1901789792 NOTICE: -----------------------------------------------------------------------
2019-06-29 16:39:41.713 T:1901789792 NOTICE: Starting Kodi (18.2 Git:20190428-a94ccc8ba5). Platform: Linux ARM 32-bit
2019-06-29 16:39:41.713 T:1901789792 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-06-29 16:39:41.713 T:1901789792 NOTICE: Kodi compiled 2019-04-30 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-06-29 16:39:41.713 T:1901789792 NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98-v7
2019-06-29 16:39:41.714 T:1901789792 NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-06-29 16:39:41.714 T:1901789792 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2019-06-29 16:39:41.714 T:1901789792 NOTICE: ARM Features: Neon enabled
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://masterprofile/ is mapped to: /root/.kodi/userdata
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://envhome/ is mapped to: /root
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://home/ is mapped to: /root/.kodi
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://temp/ is mapped to: /root/.kodi/temp
2019-06-29 16:39:41.714 T:1901789792 NOTICE: special://logpath/ is mapped to: /root/.kodi/temp
2019-06-29 16:39:41.714 T:1901789792 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi_v7
2019-06-29 16:39:41.714 T:1901789792 NOTICE: Local hostname: local-kodi
2019-06-29 16:39:41.715 T:1901789792 NOTICE: Log File is located: /root/.kodi/temp/kodi.log
2019-06-29 16:39:41.715 T:1901789792 NOTICE: -----------------------------------------------------------------------
2019-06-29 16:39:41.715 T:1901789792 INFO: loading settings
2019-06-29 16:39:41.736 T:1901789792 NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-06-29 16:39:41.800 T:1901789792 DEBUG: CSkinSettings: no <skinsettings> tag found
2019-06-29 14:39:41.823 T:1901789792 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-06-29 14:39:41.823 T:1901789792 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<video>
</video>
<samba>
</samba>
<cache>
</cache>
</advancedsettings>
2019-06-29 14:39:41.823 T:1901789792 WARNING: CSettingsManager: missing version attribute
2019-06-29 14:39:41.832 T:1901789792 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-06-29 14:39:41.832 T:1901789792 NOTICE: Default Video Player: VideoPlayer
2019-06-29 14:39:41.832 T:1901789792 NOTICE: Default Audio Player: paplayer
2019-06-29 14:39:41.833 T:1901789792 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-06-29 14:39:41.833 T:1901789792 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-06-29 14:39:42.735 T:1901789792 ERROR: SQL: [Addons27.db] SQLite error SQLITE_ERROR (no such table: version)
Query: SELECT idVersion FROM version
Delete your userdata/Database/Addon27.db file, apparently it is malformed/corrupted.
Also, next time use a pastebin website for providing log files and snippets.
(2019-06-29, 16:46)Klojum Wrote: [ -> ]ERROR: SQL: [Addons27.db] SQLite error SQLITE_ERROR (no such table: version)
If I delete this file I am back on start.
Kodi starts but there is nothing on screen.
