Hi
Am on Kodi 18.3 and (still) have issues when watching vid. Every 8-10 mins suddey the vid starts to accellerate and becomes “jumpy” and audio seems correct.
Happens with multiple vids. Running on Minix U9H.
Anybd else getting this?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
