Full Version: sonos integration to Kodi
Hello all
I need to further develop my media solution
I am planing to add speakers to one of my laptops i use in a room and i am considering sonos speakers to be paired with that speaker. I trowelled the forum and i found old threads on this subject that may or may not apply to the current environment. Kodi 18 is installed on this laptop. This would be a test for this solution
I have
1 HTPC that is channelled via a stereo system Mostly used to listen to music
1 new HTPC that i would build a 5.1 environment ( next spring) mostly used to watch video
2 laptops one (the one mentioned here above) to listen to music and a second one which will be used for Music and video
Is the integration of sonos play3 possible ?
if So
how?
Thank you for your responses
