Has anyone had success in hardware decode of the Astra 8K satellite channel? My system plays it like a slide show using cpu decode with Intel GPU and Kodi 18.3 and my AMD RX480 with VLC Nightly cant handle it either.
Codec Details are as follows:
Codec: MPEG-H Part2/HEVC
Video Resolution: 7680*4320
Frame Rate: 50.0
Colour Primaries: ITU-R BT.2020
Colour Transfer Function: Hybrid Log-Gamma
Bitrate is around 80Mbit
I'll repost my image from the coreelec forums
I can play it fine on my windows machine with HW decoding
(2019-07-04, 21:09)komplex Wrote: [ -> ]I'll repost my image from the coreelec forums
Awesome. Whats the hardware?
Guess that means only Nvidia supports 8K decode right now. Recentish AMD and Intel fail.
(2019-07-04, 22:23)Krobar Wrote: [ -> ]Guess that means only Nvidia supports 8K decode right now. Recentish AMD and Intel fail.
My nothing special i3 7th gen laptop was having a good go at playing it in MPC HC without me looking at optimising it. I think 8K HEVC decode is not that unusual in current GPUs?
For info this is the full Media Info report on it (though I made the recording using ffmpeg from a network stream so the PIDs may be different). They are using a strange 1.0 centre-channel only audio stream - unless there is some odd-ball audio that is falling back to this?
Format : MPEG-TS
File size : 7.25 GiB
Duration : 13mn 43s
Overall bit rate mode : Variable
Overall bit rate : 75.6 Mbps
Video
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L6@Main
Codec ID : 36
Duration : 13mn 43s
Width : 7 680 pixels
Height : 4 320 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
Matrix coefficients : BT.2020 non-constant
Audio
Menu ID : 1 (0x1)
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Format version : Version 4
Muxing mode : ADTS
Codec ID : 15-2
Duration : 13mn 43s
Bit rate mode : Variable
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 SPF)
Compression mode : Lossy
Delay relative to video : -1s 707ms
