Full Version: How to use artwork stored on NAS with movie ?
Hi all !
(Sorry for my bad english)
I store movies in separate folder on a NAS. I use "Media Center Master" for scrap abd download poster and folder pictures into those folders.
How can I force Kodi to use those ressources instead of downloading again please ?
Thanks in advance !
@Nicodeme
Kodi will always use local information first, so if you have your Artwork correctly named and saved Kodi will use it.
Look at the image at the bottom of this page in Section 2- Local Artwork, which displays how to save your artwork, and other files... https://kodi.wiki/view/Movie_artwork
If you do not have your artwork saved this way with the movie, then Kodi will not find it.
(2019-07-04, 22:07)Karellen Wrote: [ -> ]@Nicodeme
Ah, i see what's wrong i think...
I have backdrop.jpg instead of <name of file>-backdrop.jpg. Is this my mistake ?
(2019-07-04, 22:11)Nicodeme Wrote: [ -> ]I have backdrop.jpg
Kodi does not use "backdrop.jpg". You must name it fanart as shown in the image.
(2019-07-04, 22:13)Karellen Wrote: [ -> ]
Yes, fanart.jpg but as I see, <file name>-fanart.jpg.
I think my scrapper tool is to old. Is there something good and easy to use for scrap instead of Media Center Master please ?
(2019-07-04, 22:17)Nicodeme Wrote: [ -> ]I think my scrapper tool is to old. Is there something good and easy to use for scrap instead of Media Center Master please ?
I recommend that you let Kodi scrape your library. Kodi does not need Media Managers to populate the library.
But if you must have a Media Manager then I suggest Ember Media Manager, Tiny Media Manager or Media Companion from here... https://forum.kodi.tv/forumdisplay.php?fid=116
(2019-07-04, 22:29)Karellen Wrote: [ -> ]
Yes, i need a scraper because i have 2 kodi and 1 MySQL DB that i manage from my PC.  Wink
Thanks for your responses !
