2008-07-02, 22:47
Sorry for the terse msg but keeping it under 10000 chars. Getting "Too many consecutive failed items" error. Tried once with VeohProxy running, once without it running. Log below is with VeohProxy running. Help? Thx.
16:13:49 M: 38121472 DEBUG: DIRECTORY::CPluginDirectory::GetDirectory - calling plugin Q:\plugins\video\Ninjavideo\default.py('plugin://video/Ninjavideo/','1','?url=http%3A%2F%2Fwww.ninjavideo.net%2Fvideo%2F7371&mode=4&name=Memento+%282000%29')
16:13:49 M: 37597184 DEBUG: DIRECTORY::CPluginDirectory::WaitOnScriptResult - waiting on the Ninjavideo plugin...
16:13:49 M: 37597184 INFO: Mode: 4
16:13:49 M: 37597184 INFO: URL: http://www.ninjavideo.net/video/7371
16:13:49 M: 37597184 INFO: Name: Memento (2000)
16:13:49 M: 37597184 INFO: index of videolinks : http://www.ninjavideo.net/video/7371
16:13:49 M: 37609472 INFO: Scriptresult: Succes
16:13:49 M: 37609472 DEBUG: DIRECTORY::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
16:13:49 M: 37568512 INFO: Python script stopped
16:13:50 M: 36827136 DEBUG: CApplication::OnKey: 11 pressed, action is 7
16:13:50 M: 36790272 INFO: XCURL:llLibCurlGlobal::easy_aquire - Created session to http://127.0.0.1
16:13:50 M: 36790272 DEBUG: Curl:: Debug About to connect() to 127.0.0.1 port 64653 (#0)
16:13:50 M: 36790272 DEBUG: Curl:: Debug Trying 127.0.0.1...
16:13:50 M: 36790272 DEBUG: kernel32.dll fake function FormatMessage called
16:13:50 M: 36790272 DEBUG: Curl:: Debug Unknown error 0 (0x0)
16:13:50 M: 36790272 DEBUG: Curl:: Debug couldn't connect to host
16:13:50 M: 36790272 DEBUG: Curl:: Debug Closing connection #0
16:13:50 M: 36790272 DEBUG: Curl:: Debug couldn't connect to server
16:13:50 M: 36790272 DEBUG: FileCurl::Close(D009FD24) http://127.0.0.1:64653/7371?.avi
16:13:50 M: 36790272 DEBUG: CPlayerCoreFactor::GetPlayers(http://127.0.0.1:64653/7371?.avi)
16:13:50 M: 36790272 ERROR: XFILE::CFile:elete - Error deleting file Z:\xbmc.edl
16:13:50 M: 36790272 DEBUG: file:http://127.0.0.1:64653/7371?.avi IsDVDImage:0 IsDVDIfoFile:0
16:13:50 M: 36790272 INFO: Loading skin file: DialogProgress.xml
16:13:50 M: 36790272 DEBUG: Load DialogProgress.xml: 39.13ms (36.72 ms xml load)
16:13:50 M: 36737024 DEBUG: Alloc resources: 26.64ms (0.00 ms skin load, 0.34 ms preload)
16:13:51 M: 35823616 INFO: mplayer play:http://127.0.0.1:64653/7371?.avi cachesize:4096
16:13:51 M: 35823616 DEBUG: Initializing FS_SEG..
16:13:51 M: 35823616 DEBUG: FS segment @ 0xcd35a0
16:13:51 M: 29941760 DEBUG: msg: set audio functions called
16:13:51 M: 29941760 DEBUG: msg: done
16:13:51 M: 29941760 DEBUG: FileCurl::Open(00B1C650) http://127.0.0.1:64653/7371?.avi
16:13:51 M: 29839360 DEBUG: Curl:: Debug About to connect() to 127.0.0.1 port 64653 (#0)
16:13:51 M: 29839360 DEBUG: Curl:: Debug Trying 127.0.0.1...
16:13:51 M: 29839360 DEBUG: kernel32.dll fake function FormatMessage called
16:13:51 M: 29839360 DEBUG: Curl:: Debug Unknown error 0 (0x0)
16:13:51 M: 29839360 DEBUG: Curl:: Debug couldn't connect to host
16:13:51 M: 29839360 DEBUG: Curl:: Debug Expire cleared
16:13:51 M: 29839360 DEBUG: Curl:: Debug Closing connection #0
16:13:51 M: 29839360 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
16:13:51 M: 29839360 DEBUG: FileCurl::Close(00B1C650) http://127.0.0.1:64653/7371?.avi
16:13:51 M: 29941760 INFO: Using -subcp enca:__:CP1252 to detect the subtitle charset
16:13:51 M: 29941760 INFO: Flipping bi-directional subtitles disabled
16:13:51 M: 29941760 DEBUG: msg: mplayer_init()
16:13:51 M: 29941760 DEBUG: msg: MPlayer XBMC-SVN-r10070-4.1.2 © 2000-2004 MPlayer Team
16:13:51 M: 29941760 DEBUG: msg: CPU: Intel Celeron 2/Pentium III Coppermine,Geyserville
16:13:51 M: 29941760 DEBUG: msg: (Family: 6, Stepping: 10)
16:13:51 M: 29941760 DEBUG: msg: Detected cache-line size is 32 bytes
16:13:51 M: 29941760 DEBUG: msg: CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
16:13:51 M: 29941760 DEBUG: msg: Compiled for x86 CPU with extensions:
16:13:51 M: 29941760 DEBUG: msg: MMX
16:13:51 M: 29941760 DEBUG: msg: MMX2
16:13:51 M: 29941760 DEBUG: msg: SSE
16:13:51 M: 29929472 DEBUG: msg:
16:13:51 M: 29941760 DEBUG: msg: Creating config file: Q:\system\players\mplayer\config
16:13:51 M: 29941760 DEBUG: msg: get_path('codecs.conf') -> 'Q:\system\players\mplayer\codecs.conf'
16:13:51 M: 29941760 DEBUG: msg: Reading Q:\system\players\mplayer\codecs.conf:
16:13:51 M: 29618176 DEBUG: msg: 108 audio & 225 video codecs
16:13:51 M: 29618176 DEBUG: msg: CommandLine:
16:13:51 M: 29618176 DEBUG: msg: '-dr'
16:13:51 M: 29618176 DEBUG: msg: '-v'
16:13:51 M: 29618176 DEBUG: msg: '-subcp'
16:13:51 M: 29618176 DEBUG: msg: 'enca:__:CP1252'
16:13:51 M: 29618176 DEBUG: msg: '-channels'
16:13:51 M: 29618176 DEBUG: msg: '6'
16:13:51 M: 29618176 DEBUG: msg: '-a52drc'
16:13:51 M: 29618176 DEBUG: msg: '1'
16:13:51 M: 29618176 DEBUG: msg: '-noflip-hebrew'
16:13:51 M: 29618176 DEBUG: msg: '-noflip-hebrew-commas'
16:13:51 M: 29618176 DEBUG: msg: '-fs'
16:13:51 M: 29618176 DEBUG: msg: '1.avi'
16:13:51 M: 29618176 DEBUG: msg: get_path('font/font.desc') -> 'Q:\system\players\mplayer\font/font.desc'
16:13:51 M: 29089792 DEBUG: msg: font: can't open file: Q:\system\players\mplayer\font/font.desc
16:13:51 M: 29089792 DEBUG: msg: font: can't open file: Q:\system\players\mplayer/font/font.desc
16:13:51 M: 29618176 DEBUG: msg: Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay
16:13:51 M: 29593600 DEBUG: msg: Using XBOX High Resolution Timers for timing
16:13:51 M: 29593600 DEBUG: msg: get_path('input.conf') -> 'Q:\system\players\mplayer\input.conf'
16:13:51 M: 29593600 DEBUG: msg: Parsing input config file Q:\system\players\mplayer\input.conf
16:13:51 M: 29585408 DEBUG: msg: Input config file Q:\system\players\mplayer\input.conf parsed: 51 binds
16:13:51 M: 29585408 DEBUG: msg: mplayer_open_file(http://127.0.0.1:64653/7371?.avi)
16:13:51 M: 29585408 DEBUG: msg: get_path('7371?.avi.conf') -> 'Q:\system\players\mplayer\7371?.avi.conf'
Playing http://127.0.0.1:64653/7371?.avi.
16:13:51 M: 29585408 DEBUG: msg: find subtitles
16:13:51 M: 29585408 DEBUG: msg: auto open Z:\subtitle
16:13:51 M: 29585408 DEBUG: msg: Filename for url is now http://127.0.0.1:64653/7371?.avi
16:13:51 M: 29585408 DEBUG: msg: protocol:http
16:13:51 M: 29585408 DEBUG: msg: open stream protocol:http
16:13:51 M: 29564928 DEBUG: msg: WINSOCK2 init: 0
16:13:51 M: 29564928 DEBUG: msg: Filename for url is now http://127.0.0.1:64653/7371?.avi
16:13:51 M: 29564928 DEBUG: msg: Connecting to server 127.0.0.1[127.0.0.1]:64653 ...
16:13:51 M: 29564928 DEBUG: msg: Error while sending HTTP request: Didn't send all the request.
16:13:51 M: 29564928 DEBUG: msg: Unable to open URL: http://127.0.0.1:64653/7371?.avi
16:13:51 M: 29564928 DEBUG: msg: unable to open stream
16:13:51 M: 29564928 ERROR: CMPlayer::OpenFile http://127.0.0.1:64653/7371?.avi failed with code 0
16:13:51 M: 29564928 DEBUG: msg: mplayer_close_file()
16:13:51 M: 29564928 DEBUG: msg: uninit_player
16:13:51 M: 29917184 DEBUG: msg: uninit_player - done
16:13:51 M: 29917184 DEBUG: Freeing FS segment @ 0xcd35a0
16:13:51 M: 29917184 DEBUG: Q:\system\players\mplayer\mplayer.dll (base 018A0000): Detected memory leaks: 25 leaks
16:13:51 M: 29937664 DEBUG: leak caller address 18a10cc, size 128, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18ae000, size 4, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18ae1d5, size 40, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18ae2a9, size 72, counter 2
16:13:51 M: 29937664 DEBUG: leak caller address 18ae49b, size 8, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18ae4b3, size 0, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18bd469, size 0, counter 5
16:13:51 M: 29937664 DEBUG: leak caller address 18c3106, size 0, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18c312b, size 0, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 18c3151, size 0, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 193afb0, size 44, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 1952075, size 16488, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 1959026, size 28, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 1959096, size 0, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 19590f1, size 5, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 19592cf, size 10, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 1959325, size 0, counter 1
16:13:51 M: 29937664 DEBUG: leak caller address 195cf29, size 77, counter 3
16:13:51 M: 29937664 DEBUG: mplayer.dll: Total bytes leaked: 16904
16:13:51 M: 35819520 ERROR: Playlist Player: skipping unplayable item: 0, path [http://127.0.0.1:64653/7371?.avi]
16:13:51 M: 35819520 DEBUG: Playlist Player: too many consecutive failures... aborting playback
16:13:51 M: 35819520 INFO: Loading skin file: DialogOK.xml
