Full Version: EPG Loads but no channels (LIBREELEC frontend, UBUNTU backend)
Hey,
Think i've set up everything correctly on MythTV Backend, it seems to pull through all the channels and the EPG listings etc correctly for my region.
I then however remove my tuner and plug it into the Intel NUC leaving the backend running and whilst it then correctly imports the EPG all channels seem to be unavailable. Kodi is connected successfully to my backend instance.
Using MythFrontend also i can't seem to access any channels - Does anyone have any ideas / know what logs to provide.
Just a thought, but have you tried leaving the tuner where it is ?
