(2020-02-20, 11:31)Konon Wrote: [ -> ]Tested - PNG is only good when the poster is separate from the box, as in the video from @chrissix.
I tried another option. I liked it.
I cannot give further advice cause now i am on the way...
I just can say don't play around with .png or aspect ratio stuff on original poster... poster are .jpg stuff!
Leave the original poster just how they are...
You will never get perfection here... if the skin use it with native aspect ratio it's good, but else they have to live with a bit of stretching.
Original is original and should be original, just make sure each own poster set have same resolution and aspect ratio.
But sure on the polished poster you can consider a uniform resolution and aspect ratio for uniformity... make you own conventions for this!
You also pm'd me cause of the upload naming... this is not important at all cause the KyraDB storaging makes this job.
Naming is only important for set number and poster poster... for wich artwork type it is you just have to upload it in the right section. Then it will storaged and distinguished the right way.
If it's not english changing language tag afterwards and then all is fine in API (type (orignal poster, polished poster, textless poster), language tag, set number, poster numbers in the set...)
EDIT: You achievement on original posters can also be done by skinners with the skinning engine, just making poster smaller, individual background, width/height centering or put it on bottom or top.
Good workaround by the way for different aspect ratios, i'll try that when i come back. But leave original stuff, original stuff.
Ok i have really to go now... good luck!
