Full Version: Main bar disappeared after installing eminence theme APPLE TV 4K
hello
anyone knows about my issue?
i tried deleting kodi from nito TV but for some reason after a fresh install kodi still shows the same picture as i installed eminence theme and i have no nav bar
please help
It's not automatically a bug when something works differently than expected.
You installed Kodi on an AppleTV device via some unknown vague 3rd party website.
Normally the Kodi application and its settings are stored separately, so reinstalling Kodi will not affect the settings already present.
If you want to make a fresh start, then you need to delete the Kodi profile folder, and restart Kodi.
Well, with ssh I tired deleting the whole Kodi folder, which apparently didn’t do the trick also
Another way maybe?
(2019-07-12, 00:11)alioop1 Wrote: [ -> ]Well, with ssh I tired deleting the whole Kodi folder, which apparently didn’t do the trick also
Another way maybe?
If you have access with ssh I would try to look for the user folder of Kodi and delete it as well. Maybe some entries of script.skinshortcuts that is used by eminence are causing the problem.
i tired everything.. same issue comes up
