Full Version: Scraping difficult movies / shows (example: xxxHolic)
Hi!
I cannot get themoviedb scraper to work reliably. Simple stuff is fine, but as soon as there are multiple similarly named items, the scraper does not catch the data correctly.
I read the FAQ / linked-to helper threads and tried a lot.
Let me use an example, the franchise "xxxHolic". It exists as TV shows and movies, in various seasons, and the TV show exists as anime and as real-life TV show. Here is themoviedb data:
TV shows
1. "xxxHOLiC (2006)" - https://www.themoviedb.org/tv/36250
2. "xxxHolic: Kei (2008)" - https://www.themoviedb.org/tv/67031
3. "xxxHolic: Shunmuki (2009)" - https://www.themoviedb.org/tv/67032
4. "Clamp xxxHolic (2013)" - https://www.themoviedb.org/tv/46290
Of these, 1. and 2. are considered season 1 and 2, while 3 is a separate show. 1-3 are anime, 4. is the live-action show.
Now, when I set it up exactly like this (folder names in quotation marks, a parsing.nfo file with the link) I get the following results:
Under TV shows, it finds 1. and 2. but not 3. and 4. Under Files / TV shows, it finds all, none has artwork.
Movies
5. "xxxHOLiC The Movie: A Midsummer Night's Dream (2005)" - https://www.themoviedb.org/movie/38567
6. "xxxHolic Ro (2010)" - https://www.themoviedb.org/movie/53269
7. "xxxHolic Ro Adayume (2011)" - https://www.themoviedb.org/movie/405326
It finds 5. but not 6. and 7. for under "Movies". Under files, all three can be found. Under files, none has artwork.
Any thoughts?
All of this applies in other cases as well. I notice how many videos I have under files that don't show up at all under movies and TV shows. Is there any way to see what Kodi doesn't catch? So I can work my way through file nameing, parsing.nfo and other stuff?
Thanks!!
@ks03470
I had no problem scraping the items you could not scrape.
Please provide a Debug Log which captures you trying to scrape these items.
(2019-07-13, 14:17)ks03470 Wrote: [ -> ]Under files, all three can be found. Under files, none has artwork.
Yes, of course you will see them. Vides>Files is a File Manager, so you would see everything. The Movies and TV Show menu items are library views so you will only see what has been scanned/scraped into the library.
Moved to metadata forums
