Full Version: re-Introduction of the res update issue.
KodiSetup-20190712-c341779a-master-x64 19 Alpha
as compared to functioning Kodi 18.3
A 1080p HD updated file previously scraped as 480 SD, retains the SD tag in the meta-data.
Expected behavior as exhibited by Kodi 18.3, a qucik play/sniff the of the video updates the meta-data resolution.
Yes, the previous fix seemed to not work correctly and was wiping streamdetails data.... https://github.com/xbmc/xbmc/issues/15934
New fix on the way...
https://github.com/xbmc/xbmc/pull/16239
https://github.com/xbmc/xbmc/pull/16342
+1 I see you're on top of things Smile
"That is a shame." Thanks for the update, and yes it is.
