2019-07-15, 12:52
This problem has existed since 18.0 was first released. 18.3 has been released and the problem still exists. I believe it is contained within the new add-ons for handling compressed files. Versions up through 17.6 did not have a problem with updating my libraries or going into folders, but since 18 has come out I cannot go into a folder. Uncompressing every RAR/ZIP file I have is not a viable option. One of the many files that this crash occurs on is sonarqube-7.9.zip which will crash the application if the file is in a folder by itself or with others. I have repeated the crash on multiple systems.
1. Kodi 18.3 Leia
2. Windows 10 Pro 1903 (OS Build 18362.239)
3. Intel Celeron CPU N2820 @ 2.13GHZ
4. 4 GB
5. Start Kodi up. Go down to Videos. Click on the media server. Click on a folder that has a compressed file in it. System crashes. The file I used that will always crash is sonarqube-7.9.zip. Unable to scan the libraries as well.
6. More than likely the add-on for RAR/ZIP compatibility within the application.
7. https://paste.kodi.tv/ohuqemuvac.kodi
Just in case here's the video/audio specs.
1. Video Card is just Intel HD Graphics from the Intel Corporation DN2820FYK
2. Intel Display Audio
3. Not a playback problem since I can't play anything.
Reproduceable on multiple systems
1. Kodi 18.3 Leia
3. Intel Core i7-3820 @ 3.60GHz
4. 56 GB
5. Same as above.
6. Same as above.
7. https://paste.kodi.tv/aqayexavat.kodi
1. NVidia GeForce GTX 1080
2. Realtek High Definition Audio
Another system reproduced on
1. Kodi 18.3 Leia
3. Intel Core i7-9700K @ 3.60GHz
4. 32 GB
5. Same as above.
6. Same as above.
7. https://paste.kodi.tv/gecayeviso.kodi
1. NVidia GeForce GTX 1070
I also have the dmp files upon request.
1. Kodi 18.3 Leia
4. 4 GB
1. Kodi 18.3 Leia
4. 56 GB
5. Same as above.
6. Same as above.
1. Kodi 18.3 Leia
4. 32 GB
5. Same as above.
6. Same as above.
