there will be nothing else add to this skin so do not ask
5 programmable widgets per menu item with 5 view types
home menu order extra menus items
programmable widgets from library node editor or smart playlist (video or music)
drive path for nas storage
link playlists stored on a nas
password protect feather master user + up to 3 kids
https://drive.google.com/open?id=10zeOvV...6UROw3yt_B
library node editor and how it works
creating a widget
pick a widget slot and give a name to show poster you will need to give it a name.xml eg: christmas.xml
create new widget christmas with out .xml
Looking forward to your skin being finished, I have a question for me, will it have a "collapsable", main menu like estuarymodv2 ?
Looking great sir , thanks for this.
Are you planning to release this please ?
setting up simple playlist
install plugin.library.node.editor
map button using kodi keymap editor
https://kodi.wiki/view/Add-on:Keymap_Editor RunPlugin(plugin://script.simpleplaylists/?mode=addCurrentUrl)
xml:
<global>
<keyboard>
<f2>RunPlugin(plugin://script.simpleplaylists/?mode=addCurrentUrl)</f2>
<!-- <f4>!Skin.HasSetting(HomeMenuNocustom3Button)</f4> -->
<f4>Skin.ToggleSetting(HomeMenuNocustom3Button)</f4>
<F5>XBMC.ReloadSkin()</F5>
<F7>Notification(Testing 123,Hello world)</F7>
<F8>Skin.ToggleDebug()</F8>
</keyboard>
</global>
</keymap>
windows keymap
open movies pick movies (press keymap key) add to a list
to create a node to display simple playlist
create new node in folder simpleplaylist
add path
setting widget
youtube nodes
xml:
<?xml version='1.0' encoding='UTF-8'?>
<node type="folder">
<label>Recommendations</label>
<path>plugin://plugin.video.youtube/special/recommendations/</path>
</node>
<label>subscriptions</label>
<path>plugin://plugin.video.youtube/special/new_uploaded_videos_tv/</path>
</node>
<label>subscriptions list</label>
<path>plugin://plugin.video.youtube/subscriptions/list/</path>
</node>
<label>youtube</label>
<path>plugin://plugin.video.youtube/</path>
</node>
Very nice this, thanks mate.
script.categories
open categories add a categorie
open add on and add plugins to list
now open node editor create node
add path
pick plugin...
categories
open categories to use
link path to here
note if this is not working right you may need to add to favourites and change node link
node link<path>plugin://script.categories/?url=freeview&mode=listCat&content_type=video</path>
favourites link plugin://script.categories/?content_type=video&mode=listCat&url=freeview
Just picking up on that post you made about transparency/overlay in another thread, I added a light coloured BG to jade , but when opening home screen , its has a darker overlay which I cant find where to disable it?
My BG is just set with <texture></texture> , no color diffuse text .
(2019-12-01, 11:17)ontap Wrote: [ -> ]Just picking up on that post you made about transparency/overlay in another thread, I added a light coloured BG to jade , but when opening home screen , its has a darker overlay which I cant find where to disable it?
will need to edit home and remove
<control type="group">
<height>1080</height>
<control type="image">
<top>-320</top>
<left>-130</left>
<width>110%</width>
<texture colordiffuse="88FFFFFF">colors/black.png</texture>
<visible>!Skin.HasSetting(High_Contrast)</visible>
</control>
<top>-320</top>
<left>-130</left>
<width>110%</width>
<texture colordiffuse="75FFFFFF">colors/black.png</texture>
<visible>Skin.HasSetting(High_Contrast)</visible>
</control>
the best image pack for changing images is resource.images.skinbackgrounds.clear
\Kodi\addons\resource.images.skinbackgrounds.clear\resources images are in jpg format
custom image names
custommenu_1
custommenu_2
custommenu_3
custommenu_4
custommenu_5
myhome
skinsearch
service.library.data.provider
script.embuary.helper
script.skin.helper.widgets
can be used to provide data to widgets
after testing on kodi 19 plugin.library.node.editor would not work so i have change file type from only node to file (playlist anyware)
folder folderpath
or link
Movies videodb://movies/genres/
MovieTitles videodb://movies/titles/
library://video/movies/
widget type
main menu order
