2019-07-15, 16:50
I have movies in the library with alternate versions (Director's Cut, Alternate camera angles, etc.)
All versions are in the same folder, with the same title using [brackets] to differentiate them.
Example:
Phantom Regiment 2017
----Phantom Regiment 2017[Multi Camera].mkv
----Phantom Regiment 2017[High Camera].mkv
In the past, (just before the last update I think) these were detected and only one listing would show, allowing me to set artwork, metadata for all versions.
Now each version is listed separately. The contents of the brackets are not showing in the listing, but there are still multiple entries.
Screen shots below:
Past: One entry on the left for two movies in the folder
Current: One entry on the left for EACH movie in the folder
Example:
Screen shots below:
