Full Version: script.embuary.helper - a skin helper service / widgets alternative
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
You must be calling something. Like the dbid info action or something similar.
Can you please add "log(str(self.action) + ' ' + str(self.params), force=True)" before this line https://github.com/sualfred/script.embua...ult.py#L38 ?
This will log the called action so I can see where it was called and with which params.
(2020-01-25, 14:05)sualfred Wrote: [ -> ]You must be calling something. Like the dbid info action or something similar.
Will do it tomorrow, must leave now.but didnt want leave uncommented...
I did what you suggested and upload file again, and packed in zip.
LogError pops by opening window(movieinformation)-
After i Refresh i can get image blurred, but if i refresh next one, the previous one is gone again. pretty strange and i have no idea (Nfo arent the issue, but i deleted them anyway)
Video, to get visual feedback.  -> LINK
(bridge of spies takes up to one minute for refresh 0:44 to 1:45...)
Zip File (Packed, MyVideos.db , .log)  -> LINK
EDIT:
I also test just change fanart - which is used for the blur
  1- if i choose an 'online' source , the image refreshes and blur works
  2.- if i choose a local stored art, embuary h. is not able to blur it
... BUT THAT JUST COUNT SOME FOR ITEMS - see log - (e.g. 'Bridge of Spies', 'Bringing Out The Dead' in that case)
, others are fine and also blur working flawless, regardless if cached from local/online (e.g. 'Braveheart' in that case).
IT SEEMS THE ERROR OCCURS ON ALL ITEMS WITH UMLAUTS
- again video -> LINK
NOTICE: [ script.embuary.helper ] encode {'string': '\'"Bridge of Spies: Der Unterh\xc3\xa4ndler"\'', 'prop': 'EncodedTitle'}
2020-01-26 00:30:21.600 T:25344   ERROR: XFILE::CDirectory::GetDirectory - Error getting H:\Filme\Bridge of Spies Der Unterhändler (2015)\extras
2020-01-26 00:30:21.684 T:10576   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.UnicodeDecodeError'>
                                            Error Contents: 'ascii' codec can't decode byte 0xc3 in position 27: ordinal not in range(128)
                                              File "C:\apps\Kodi Leia\portable_data\addons\script.embuary.helper\default.py", line 44, in <module>
                                                Main()
                                              File "C:\apps\Kodi Leia\portable_data\addons\script.embuary.helper\default.py", line 19, in __init__
                                                self.getactions()
                                              File "C:\apps\Kodi Leia\portable_data\addons\script.embuary.helper\default.py", line 40, in getactions
                                                util(self.params)
                                              File "C:\apps\Kodi Leia\portable_data\addons\script.embuary.helper\resources\lib\utils.py", line 208, in encode
                                                winprop(prop,url_quote(string))
                                              File "C:\apps\Kodi Leia\portable_data\addons\script.embuary.helper\resources\lib\helper.py", line 125, in url_quote
                                                string = string.encode('utf-8')
                                            UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 27: ordinal not in range(128)
2020-01-26 00:30:22.015 T:5688  NOTICE: [ script.embuary.helper ] Image blurring: Image has not changed. Skip https://assets.fanart.tv/fanart/movies/2...ccce17.jpg.
2020-01-26 00:30:22.021 T:17740  NOTICE: [plugin.video.youtube] Running: YouTube (6.5.2) on Leia (Kodi-18.5) with Python 2.7.13
                                                Path: /search/
                                                Params: {'q': 'Bridge of Spies: Der Unterh\xc3\xa4ndler'}
2020-01-26 00:30:22.557 T:5688  NOTICE: [ script.embuary.helper ] Image blurring: Image changed. Blur https://assets.fanart.tv/fanart/movies/8...a77c0d.jpg.
2020-01-26 00:30:23.328 T:13052  NOTICE: [ script.embuary.helper ] lookforfile {'file': '\'"H:\\Filme\\Bringing Out the Dead - N\xc3\xa4chte der Erinnerung (1999)\\Bringing Out the Dead - N\xc3\xa4chte der Erinnerung (1999)-trailer.mp4"\'', 'prop': 'trailer_avail'}
2020-01-26 00:30:23.352 T:13052  NOTICE: [ script.embuary.helper ] File does not exist: H:\Filme\Bringing Out the Dead - Nächte der Erinnerung (1999)\Bringing Out the Dead - Nächte der Erinnerung (1999)-trailer.mp4
2020-01-26 00:30:23.527 T:5688  NOTICE: [ script.embuary.helper ] Average color: FFa27f65
2020-01-26 00:30:24.038 T:5688  NOTICE: [ script.embuary.helper ] Image blurring: Image changed. Blur https://assets.fanart.tv/fanart/movies/2...ccce17.jpg.
2020-01-26 00:30:24.686 T:22632  NOTICE: [ script.embuary.helper ] lookforfile {'file': '\'"H:\\Filme\\Bridge of Spies Der Unterh\xc3\xa4ndler (2015)\\Bridge of Spies Der Unterh\xc3\xa4ndler (2015)-trailer.mp4"\'', 'prop': 'trailer_avail'}
2020-01-26 00:30:24.693 T:22632  NOTICE: [ script.embuary.helper ] File does not exist: H:\Filme\Bridge of Spies Der Unterhändler (2015)\Bridge of Spies Der Unterhändler (2015)-trailer.mp4
2020-01-26 00:30:24.834 T:5688  NOTICE: [ script.embuary.helper ] Average color: FF5f8c9d
2020-01-26 00:30:25.346 T:5688  NOTICE: [ script.embuary.helper ] Image blurring: Image changed. Blur https://assets.fanart.tv/fanart/movies/8...a77c0d.jpg.
2020-01-26 00:30:26.134 T:5688  NOTICE: [ script.embuary.helper ] Average color: FFa27f65
2020-01-26 00:30:26.433 T:8888  NOTICE: [ script.embuary.helper ] lookforfile {'file': '\'"H:\\Filme\\Bringing Out the Dead - N\xc3\xa4chte der Erinnerung (1999)\\Bringing Out the Dead - N\xc3\xa4chte der Erinnerung (1999)-trailer.mp4"\'', 'prop': 'trailer_avail'}
2020-01-26 00:30:26.437 T:8888  NOTICE: [ script.embuary.helper ] File does not exist: H:\Filme\Bringing Out the Dead - Nächte der Erinnerung (1999)\Bringing Out the Dead - Nächte der Erinnerung (1999)-trailer.mp4
2020-01-26 00:30:26.662 T:5688  NOTICE: [ script.embuary.helper ] Image blurring: Image has not changed. Skip https://assets.fanart.tv/fanart/movies/8...a77c0d.jpg.
2020-01-26 00:30:27.901 T:14496  NOTICE: Previous line repeats 1 times.
2020-01-26 00:30:27.901 T:14496  NOTICE: [ script.embuary.helper ] encode {'string': '\'"Bringing Out the Dead - N\xc3\xa4chte der Erinnerung"\'', 'prop': 'EncodedTitle'}
2020-01-26 00:30:28.197 T:25344   ERROR: XFILE::CDirectory::GetDirectory - Error getting H:\Filme\Bringing Out the Dead - Nächte der Erinnerung (1999)\extras
2020-01-26 00:30:28.253 T:14496   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Contents: 'ascii' codec can't decode byte 0xc3 in position 25: ordinal not in range(128)
                                                Main()
                                                self.getactions()
                                                util(self.params)
                                            UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 25: ordinal not in range(128)
@mardukL
Your log had two errors with umlauts. The "encode string" feature should be resolved now and the local image with umlauts should also work now. At least it does it on my end.
Please test my github version and keep me updated.
(2020-01-26, 09:44)sualfred Wrote: [ -> ]@mardukL
Its fixed now, using latest git. Thanks again ;-)
perfect. Pushed to my repo. Have to do a Matrix test before I'll create a PR for the Kodi repo
I am using Kodi 18.5 on my Nvidia Shield TV with Amber 3.2.31 and Embuary helper 1.3.9 downloaded from the Kodi add-on repository.
On some files (movies or tv shows), when I press the info button, I have the details that appear, but I also have a message with an Embuary helper error : https://forum.kodi.tv/showthread.php?tid...pid2912367
If I deactivate the Embuary helper, I no longer have this error message.
After several attempts, I think I have found when the Embuary helper causes an error message.
It is each time that I want to display the information window of a video with accented characters (like é, è, ê or à for example) in its title.
With videos that don't have accented characters in their title, it works fine and I don't get this error message.
Would this be a problem with only the French language ?
@sualfred, would you know where this problem with Embuary helper can come from ? Can you fix it ?
Update the script from my repo. Problem has been fixed a hand full post before.
I'll push it to the Kodi repo on the weekend.
Thank you for your quick reply @sualfred. Sorry, I had not seen the message talking about this update.
Does this new version correct errors with only umlauts or with all accented characters ?
yep. should solve it
OK, thanks.
I'll wait until this weekend to update from the Kodi repository.
Update from my repo or from the Emby repo. Or use the source from GitHub. I will submit it on the weekend that does not mean it will be available on the weekend (review process).
Hi @sualfred, Firstly thanks both for your amazing skin and this amazing addon! I'm using the calc function in this addon to work out a percentage watched for Container(tvshows) and Container(seasons). In a certain scenario I'm getting an error message. Usually it works fine, but if I rapidly press back from seasons level (i.e. Seasons > TV Shows > Home) an error below triggers:
This is the button I'm using, which is then embedded in all my focused layouts in my controls, so that if the conditions are met, it will trigger a calculation each time I scroll to a new item in any of my views:
  <include name="HiddenFocusButton">
    <control type="button">
      <visible allowhiddenfocus="true">false</visible>
      <animation effect="slide" end="0,0" time="380" reversible="false">Focus</animation>
      <onfocus condition="System.HasAddon(script.embuary.helper) + !String.IsEmpty(ListItem.Label) + !String.IsEqual(ListItem.Overlay,OverlayWatched.png) + [Container.Content(tvshows) | Container.Content(seasons)]">RunScript(script.embuary.helper,action=calc,do='"($INFO[ListItem.Property(WatchedEpisodes)] / $INFO[ListItem.Property(TotalEpisodes)]) * 100"',prop=MyResult)</onfocus>
      <onfocus condition="System.HasAddon(script.embuary.helper) + !String.IsEmpty(ListItem.Label) + [Control.IsVisible(500) + Container.Content(episodes) + !Skin.String(DetailedListView_Display,Square)]">RunScript(script.embuary.helper,action=calc,do='"($INFO[Container.TotalWatched] / $INFO[Container.NumItems]) * 100"',prop=MyResult)</onfocus>
      <onunfocus condition="!String.IsEmpty(Window(Home).Property(MyResult))">ClearProperty(MyResult,home)</onunfocus>
    </control>
  </include>
And this is the error in the log:
2020-01-30 14:51:34.898 T:123145536561152   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.SyntaxError'>
                                            Error Contents: invalid syntax (<string>, line 1)
                                              File "/Users/ahekmat/Library/Application Support/Kodi/addons/script.embuary.helper/default.py", line 43, in <module>
                                                Main()
                                              File "/Users/ahekmat/Library/Application Support/Kodi/addons/script.embuary.helper/default.py", line 19, in __init__
                                                self.getactions()
                                              File "/Users/ahekmat/Library/Application Support/Kodi/addons/script.embuary.helper/default.py", line 39, in getactions
                                                util(self.params)
                                              File "/Users/ahekmat/Library/Application Support/Kodi/addons/script.embuary.helper/resources/lib/utils.py", line 180, in calc
                                                result = eval(str(formula))
                                              File "<string>", line 1
                                                ( / ) * 100
                                            SyntaxError: invalid syntax
Here's my whole error log if it's useful: https://www.dropbox.com/s/209sdqjquwyipts/kodi.log?dl=0
And full code here: https://github.com/realcopacetic/skin.copacetic
I'd be super grateful if you could see anything I've done wrong? Thanks!
The ListItem info labels were empty that's why you got this.
(2020-01-30, 17:26)sualfred Wrote: [ -> ]The ListItem info labels were empty that's why you got this.
Ahh thanks, I'll try adding a conditional to the onfocus so it only checks if they're not empty, thanks!!
