Hello, I can not make my Auro 3D music work with Kodi. While it works perfectly with my platinum Bluray. I have an ISO of this same Bluray Auro3D but Kodi sends DTS-HD. Is Kodi unable to read the Auro3D ?
Aucune intervention. 🙃
No replies probably because it seems to be a niche format, first time I've seen it mentioned on this forum.
fritsch any idea if ffmpeg supports this? seems to be an object audio format (similar to Atmos) that can be embedded into PCM streams.
No idea to be honest. I did not follow recent ffmpeg audio format discussions.
Thank you for taking the trouble to answer something. ^^
Do you know where I could get closer to hoping for support?
Not sure why no one answered to your question on CoreELEC forum. The answer is right there in post 1:Â
https://discourse.coreelec.org/t/odroid-...uilds/4560
There is no LPCM support on N2, therefore no Auro 3D!
Edit: Sorry, should have clarified that this applies only if Auro3D on the disc is in PCM format. If it is DTS-HD MA, then it could be that the bitstream is not really bit perfect.
Auro3D requires HDMI pass through and decoding by an AVR that supports Auro decoding. Like Atmos
I’ve only one Auro3D title. Looking at the ripped version it only shows the DTS-HDMA codec in MediaInfo. This was made by MakeMKV years ago. It’s possible I didn’t select the Auro track.
I will try and find the original disc packed away in boxes in my garage, rip again with latest MakeMKV and try on my Intel NUC8 with LE 9.2 ASAP.
(2019-07-29, 10:03)HomerJau Wrote: [ -> ]I’ve only one Auro3D title. Looking at the ripped version it only shows the DTS-HDMA codec in MediaInfo. This was made by MakeMKV years ago. It’s possible I didn’t select the Auro track.
https://www.makemkv.com/forum/viewtopic.php?t=14739
[font][font]https://discourse.coreelec.org/t/ffmpeg-auro3d-supported/6281[/font][/font]
Hi, is it possible to integrate Auro3D support within ffmpeg ? Â Here is an Auro 3D audio track :
Auro 3D Sample (The link expires in 6 days)
https://transfernow.net/ddl/Auro3D-SampleÂ
