2019-07-20, 10:03
I've looked for other threads and github but I can't find this issue. In 17.6 it works fine every time. Am I missing some new setting to get it to work? I've tried with the default settings. I've tried 18.4 and 19 nighlies. Same issue.
They only work together in Windowed mode.
When both are enabled it looks like it tries to adjust refresh rate but then it hangs (screen stays black). It locks Windows too. I can only singout/restart to get Windows working properly again.
I can't access other apps, not even Task Manager, when Kodi hangs. It doesn't totally lock Windows though. E.g. Spotify keeps playing in the background and responds to keyboard media keys and I can use CTRL+ALT+DEL to access sign out/restart.
I have the same issue on both my HTPC and desktop. I can only play files in the PC's set refresh rate (23.976 and 60 Hz). The logs are only from my desktop though.
debug logs
hangs, adjust & sync: https://pastebin.com/Ne0qzbx9
working, adjust only: https://pastebin.com/L3X8gKFH
working, sync only: https://pastebin.com/WWDTm6CA
working, adjust & sync (windowed): https://pastebin.com/AjC7WLEf
Desktop / HTPC
2. Win10 1903 / 1803
3. CPU/Architecture: i5-2500K / Intel NUC5i3RYH
4. RAM amount: 16 / 4 GB
1. Video Card and Driver version: GTX 670 v388.13 / Intel HD Graphics 5500 gfx_win10_64_15.40.41.5058
2. Audio device in use (HDMI/SPDIF/RCA Audio out) and manufacturer (Intel/AMD/Creative) and driver version
Desktop: RCA, ASUS Xonar DGX, 10.0.18362.1
HTPC: RCA, Realtek, aud_win7_8.1_10_6.0.1.7982
debug logs
Desktop / HTPC
