Full Version: Little brazilian translation problem (I think)
Hi!
I found a little problem with brazilian translation (I'm Brazilian).
The problem is with the label "Temporada", witch mean "Season".
If my language is English it show "Season 1", and if I'm in Brazilian Portuguese it show "Temporada1" (without the space).
Can someone solve this?
I tried to join the translation team in Transifex, but it was already complete and I couldn't.
I hope I not bothering you guys with a silly problem.
Moved to translations
Done,  missing empty space was fixed.
strings.po file
#: xbmc/filesystem/VideoDatabaseDirectory/DirectoryNodeSeasons.cpp
msgctxt "#20358"
msgid "Season {0:d}"
msgstr "Temporada {0:d}"
(2019-07-25, 23:57)Wanilton Wrote: [ -> ]Done,  missing empty space was fixed.
strings.po file
msgctxt "#20358"
Thank you, @Wanilton!
Just one doubt: for get translations updates don't need Kodi updates, right? It's like an add-on update?
Yes, its one add-on, or edit strings.po file manually.
(2019-07-26, 18:35)Wanilton Wrote: [ -> ]Yes, its one add-on, or edit strings.po file manually.
Right! Just for curiosity, where is the location of this strings.po?
Inside your userdata, addon folder,  resource.language.pt_br\resources, there you find strings.po file, use notepad++ or other XML editor to change.
