Full Version: CBC Radio addon: select Toronto, get Charlottetown
The CBC Radio Addon for KODI by James Boston [v0.9.0] has worked great for listening to CBC Toronto until this morning:  Monday July 29.
Selecting Toronto gives you the audio feed from the CBC station in Charlottetown.
I checked many of the other channels.  The 10 or so I checked all seem fine.
I have reinstalled the Addon from the repository - no change.
Anyone got suggestions ?
-jg-
John
Also, some of the CBC Radio 2 feeds don't work correctly.
If you click on any of these:
    CBC 2 - Central Winnipeg
    CBC 2 - Eastern Toronto
    CBC 2 - International Pacific
you get this instead:
    CBC 2 - Mountain Edmonton
-jg-
(2019-07-29, 15:42)j13ag Wrote: [ -> ]As of today, July 31, the problem with CBC 1 Toronto is resolved.
It looks like the issue was at CBCs end.
-jg-
(2019-07-29, 15:42)j13ag Wrote: [ -> ]The CBC Radio Addon for KODI by James Boston [v0.9.0] has worked great for listening to CBC Toronto until this morning:  Monday July 29.
-jg-
John
Update.  As of early August, the stream for CBC Radio Toronto does not play anything.
I assume that CBC is moving things around, changing the stream URLs.
-jg-
PS
(2019-08-13, 21:24)j13ag Wrote: [ -> ]
-jg-
John
-jg-
PS
It looks like CBC has removed the URL that the plugin was using to get the radio streams.
This is the URL the plugin was using:
https://www.cbc.ca/radio/includes/stream.html
Which is not longer available.
The addon as stated above no longer works is there a fix ..thanks
Nothing yet can someone take a look this is a
A very useful add-on here in Canada
