Full Version: Skins settings reset on disconnect / reload
Hi all !
Here's my setup : NUC with LibreElec 9.0.2 and Kodi 18.2. Fresh install.
I first setup sources and regional, then i install Aeon MQ 8 from the Kodi repo.
I have created two profiles : "Parents" and "Kids", new configuration for the two.
I connect on "Parents", change settings like this :
- change "Movies" submenu for Playlist renamed "Movies" with new background, widgets movies (standard)
- change "TV Shows" submenu for Playlist renamed "TV Shows" with new background, widgets tv shows (standard)
- change "Music" submenu for Playlist renamed "Marvel" with new background, widgets movies "standard"
- etc.
I disconnect from "Parents" and connect to "Kids", same operations.
When i disconnect from "Kids" and reconnect to "Parents", skin had reset (Movies, TV Shows, Music, etc.).
When i disconnect from "Parents" and reconnect to "Kids", skin had reset (Movies, TV Shows, Music, etc.).
I paste you a settings.xml when changes are made, befeore reset...
https://paste.kodi.tv/udedahofuy.kodi
Need your help, i will turn crazy... (4 times i remade all settings, profiles, etc.)
Thanks in advance !
Please help me ^^'
It´s one bug in Kodi, nothing for to do, we need wait a proper fix, more info
https://kodi.wiki/view/Profiles#Missing_...g_profiles
Have one recent Pull Request in Kodi Matrix to try fix
https://github.com/xbmc/xbmc/pull/16420
(2019-07-31, 12:47)Wanilton Wrote: [ -> ]It´s one bug in Kodi, nothing for to do, we need wait a proper fix, more info
Hello Wanilton, thanks for your response !
Just a little precision : is a reloadskin() enough or do I have to copy the settings.xml at each reboot to keep my configuration ? If i have to copy the file at each boot, is there a code example somewhere on this please ?
Thanks again Smile
