There is a separate PR for Leia, however as the build system for Leia currently has an issue need to wait for it to be fixed.
If you can run libreelec I can request it in the test builds for Matrix if you want to try it out.
(2019-08-13, 15:42)phunkyfish Wrote: [ -> ]There is a separate PR for Leia, however as the build system for Leia currently has an issue need to wait for it to be fixed.
Alright, I see.
No, that is not necessary as I only have AndroidTV boxes running at the moment and my PCs are used for other stuff at the moment. But thank you!
Hi! Is there option to manually install this update? It seems to take quite a long time to get pulled.
Just need to wait for the review. It should be next in line.
No option to manually install unless you build the addon yourself.
Review is nearly done. Once done it’s takes 24/48 hours from release to appear on binary addon repos.
(2019-09-08, 21:21)phunkyfish Wrote: [ -> ]It's released.
Hi thanks.
I was just trying it.
Sadly it still doesn't work.
Guess I'll have to do it another way then.
Thanks for your effort anyways.
Can you provide a debug log? I tested this a lot and it work for me.
