2019-07-31, 10:27
Hi everyone,
I experience an annoying problem : after being disconnected from a profile, rebooting or stopping / starting, settings from my skin are reset...
My setup :
- NUC x64 on LibreElec 9.0.2, with Kodi 18.2
- Skin Aeon MQ8 from Kodi repo
- Database located on a NAS
- 2 profiles, "Parents" and "Enfants", so at login screen, i have "Master User", "Parents", "Enfants".
Symptom :
After a fresh install, i made the basic settings under the default skin (Estuary). After that, i created the 2 profiles. Then again, basic settings under those two. Then i switch to Aeon MQ8.
I change settings (some display settings, some submenus settings), disconnect from 1st profile to the 2nd. Change settings (about the same than the 1st profile), then disconnect and login to the 1st profile. And then, skin is reset (display settings, submenus settings, everything).
I tried to leave the first profile after making my changes, same punishment.
I spent several days looking for information on the Internet, I read several topics. I saw that users had similar problems on OSMC in 2017. I read that there was a tips by changing skin (back to the skin by default) to force Kodi to save the settings before returning to the desired skin.
But I have the impression that it is the profile of the masteruser that reapplies each time. Is there a clean way to do ? Did I misconfigure my profiles at creation ?
I'm frustrated, it's been several days since I can not finalize the configuration of these 2 profiles and this is the last thing I have to do ...
Many thanks in advance for your answers.
My setup :
Symptom :
